cv shaft nuts
cv shaft nuts
I am trying to get my cv shaft nuts off and im having a hard time. I have a 1/2" craftsman breaker bar, got the passenger side broke loose, and the drivers side wont budge. I put a 5' pipe on the end of the breaker bar and had my whole body weight on the end of it, wouldnt budge, so i pushed a little harder and snapped the head of the breaker bar in 2 pieces... anyone else have this problem?
I'm sure you already tried this but PB blaster penetrating fluid has usually helped break loose any tough nut I've encountered. Otherwise if I really can't get it I just take a hammer and a chisel and try to get it that way, it ruins the nut but if you need it off you need it off. good luck
Originally Posted by ssj4shane
try another breaker bar but with some lube on it... or a impact..
AND HEYYYYYYY you need the cv join to drive... it holds you hub in one
