Lowering tips????
Ground force lowering shackles # 91200
http://store.summitracing.com/partde...5&autoview=sku
I have these shackles and they come with pinion shims where the other companies shackle kits you have to order them separate.
Originally Posted by DLM
man, there are so many products out there to lower a vehicle and the cost varies widely too...i'm beginning to get confused...cars were sooooo much easier. i'm with 05XL, i just wanna lower the rear a bit, is that product you posted the only thing i need to buy in order to do that?
I have the GF kit on my '06 KR and I have true duals straight out the back. I should have put the drop kit on first because after about a month of driving, one of the rear exhaust pipes crushed the brake line which runs over the top of the rear diff. It cost me $450 to get it fixed at the dealer. They were nice enough to run the "new" brake line in front of the diff, so the problem will not happen again.
The GF kit has longer shackles that will raise your leaf springs two inches higher towards the bottom of your bed. Check out your bump stops and exhaust beforehand to see if you have more than two inches of clearance. If not, changes will have to be made afterwards.
KR-Texas
KR-Texas
The difference is more like 3 inches. The GF kit lowered my truck 2" and the back now sits about an inch higher. I think it looks better with a slight rake versus the 3" tilt from the factory.
When I tow my boat, the truck sits level. I think level is a little too low, as you do not have much room to spare when going over dips or bumps, etc.
KR-Texas
KR-Texas
