OK, please help me with decision.
I have went back and forth; don't know what to do. I have a 04 XLT 2wd SCrew (new body style). Should I get a leveling kit (which one daystar?) and then a 3 in body lift? I want the lifted look but nothing extreme. Does any of the body lifts level the front at the same time or do I need the leveling kit with the body lift? Sorry I just don't know how it all works but I know what I want it to look like. Thanks guys
KeithBennett is right. If you can install the Autospring leveling kit and a body lift yourself, they are a great value. However, I hear body lifts are a real pain to install on the 04-08's so shops charge a lot for labor. If you have to pay someone to install the body lift and/or a leveling kit, you will be better off to go with the 6 inch Pro Comp lift kit. This will allow you to fit 35's on your truck. I'd suggest an 18x9 inch wheel (with 5 to 6 inches of backspacing) and a set of 325/60-18 (33x13.00) or 325/65-18 (35x13.00) tires.
man I just ordered a basic fabtech kit from josh at sportztrailers. Im sure he'll hook you up . cheepest place i found his email sportztrailersjosh@comcast.com and his # 866-922-0093 just tell him your a member here.
