looks off
looks off
When I look at the back of my truck it looks like the passenger side is higher than the driver side. I don't know much about suspension but when I drive my truck on a level surface the back of it looks way off. I have been looking at it for a while and it is driving me crazy. Has anyone else had this problem? I hope so or else my eyes are very whopsided.
I kind of had the same thing too. park your truck on a level surface. Get up on the truck and work the suspension up and down really good. Now, take measurements from standard reference points(I.E. the same spot) on the rear, left and right, and on the front left and right. If there is a difference, maybee a shock is worn or leaf spring worn. if everything looks normal, maybee the torsion bars ( if you have them ) are in need of adjustment.
Hope this helps!
Hope this helps!
x2 - I had the same problem with my 2000 4x4. Only my passenger side sat lower that the drivers side by about an 1.5" to 2"... I had just put new shocks on and that wasn't the problem. I cranked up the torsion bar so the truck was level, then got an alighnment. problem solved. Took me 15 minutes to adjust the torsion bar and about $45 for the alighnment.
If it isn't your shocks, then that's probably your problem. Do what these guys said first with the measuring tape and work the suspension, if that seems OK then I would adjust the torsion bar on the drivers side.
