Popping Sound
Popping Sound
Having trouble get my truck aligned so Brakecheck put a alignment kit on my truck. Since then, I get a loud popping sound when I crank the wheel. Loud enough that the first time I heard it, I thought that I had backed into something. Can anyone give me any idea on what it could be.
'06 XLT Scab with a procomp leveling kit with Bilstein shocks
This is driving me nuts. I am getting a very similar "popping" sound as well, although I haven't installed any aftermarket components. It sounds similar to a bad u-joint but I've had both replaced. I have found it very hard at times to determine for sure if its coming from the front or back. I hear it most often going over a speed bump (very slow) or anytime the truck twists a little (like driving down thru the yard) never hear it going down the highway. I can't find anything that seems to be loose in the suspension. Like I said, its driving me nuts! Would a bad ball joint or tie rod end make that kind of sound? The truck has 98,000 miles and been pretty much pampered since day one.
Any ideas????
Bryan
Any ideas????
Bryan
Mine did it before i went LT...Only thing i could think of is that it was either the ball joint, or the coil binding or popping in the bucket. Did it at turns or slow over speed bumps. 10-15mph or under. Almost like the coil was coming out of the bucket and catching and popping back in.... But who knows
