Fabtech 6" Lift E-brake Cable Rubbing
I just lifted my 2005 F150 with a 6" Fabtech Suspension lift. My E-Brake cable is rubbing the rear tire? Anyone have this problem before? How can it be fixed?
<a href="http://photobucket.com" target="_blank"><img src="http://i34.photobucket.com/albums/d118/Silverex04/IMG_3023.jpg" border="0" alt="Photo Sharing and Video Hosting at Photobucket"></a>
<a href="http://photobucket.com" target="_blank"><img src="http://i34.photobucket.com/albums/d118/Silverex04/IMG_3020.jpg" border="0" alt="Photo Sharing and Video Hosting at Photobucket"></a>
<a href="http://photobucket.com" target="_blank"><img src="http://i34.photobucket.com/albums/d118/Silverex04/IMG_3025.jpg" border="0" alt="Photo Sharing and Video Hosting at Photobucket"></a>
<a href="http://photobucket.com" target="_blank"><img src="http://i34.photobucket.com/albums/d118/Silverex04/IMG_3026.jpg" border="0" alt="Photo Sharing and Video Hosting at Photobucket"></a>
Sometime does not look right. Do you have your reloc brkt on? Is it on right? Mine is almost touching the stock. I know the backspacing on the rims make a difference but I had stock rims on a few weeks ago with no issues.
Check the bracket.
Really?
Check the bracket.
Originally Posted by Richhit
4wd or 2wd?
there is a bracket that is installed to bring that up closer to the side of the frame rail, to keep it from making contact with the tire. there should also be a little black coupler around both lines that you can slide to make them both tighter together. double check to see if that bracket was installed. also, im not 100% positive on this, but this could be caused because of you running the stock wheels and tires.
Originally Posted by FordF1Fitty
Yeah it came with extended brake lines, front diff skid plate, everything you need. I didnt install it. Safari Off-Road did the install for me for $2583 out the door. They had the truck for 2 days.
