Achieving Optimal Softness
I own an 02 F-150 Supercrew 4x4. I am looking at how to achieve the softest ride possible, especially the sharp jolts in the rear on pot holes and rough roads. Does anyone have experience in replacing the stock leafs with something softer? Removing a leaf perhaps? I do tow but only a 2 place atv/sled trailer rated at 3500lbs so nothing strenuous.
The wife drives an 04 expedition and I would like to be able to soften the ride as it kind of spoils me of my 02 as its my daily driver but am limited with the 4x4 which i need to retain. I am intending on putting some larger tires on it as i need to replace the existing ones due to wear, so was thinking about some 15/10 AE 589's with some 32/11.5/15's or so. Was hoping a slightly larger thicker tire with a little less air might add a bit more cushion and helps in the looks department as well. I dont really want to get into a suspension lift and the cost associated and not sure if the difference in ride quality would warrant the price, as well as the fact I like to keep it parked in my garage and I have an 8' high door.
Thoughts or opinions? Replacing the truck just isnt an option.
Originally Posted by a_user
I am aware of the fact that the expedition has irs. notice i never asked how to make the truck ride as smooth. i am simply wanting to soften the ride more so then stock.
The off-road capability should be affected slightly with the removal of the overload springs but unless you are getting knee deep in it, you should be fine.
would removing a leaf not change the geometry and handling characteristics of the truck? I could see putting a new set of leafs with a different tension level and spring rate but removing a leaf entirely? Also, do the f150's even normally come with overload springs unless you get the heavy towing package or whatever they call it? I thought they used the overload spring to help balance the tongue wait and rear end sag.
Thanks for the help.
Removing the overload spring will change the geometry but the same goes for adding a drop shackle, etc. Removing the spring drops the rear by 1.5" and softens it up.
All 3 F150's I've owned have had them and none of them had the heavy duty or towing package.
Adding a new leaf pack would achieve the same result, but removing the spring and trying it out is a free alternative to try out. If it's not what you want, go spend some cash
