Newly lifted screw
Newly lifted screw
Just finished lifting my screw last weekend. Huge difference considering I had the 2" belltech drop shackles on the rear. OEM shackles with the Pro comp stage 1 kit with add a leaf in the rear. My co-workers 05 has a fabtech 6" kit on it and the front sits 1.5" taller in the front than mine. His angles also suck whereas mine are pretty flat out.
Next up are the RCD / bilstein 5100's for 6" lift up front to get rid of the spacers, and a leveling kit from top gun customz that is on it's way.
Anyone else notice that the pro comp kit is lower in the front than the fabtech? Or is it just mine?
https://www.f150online.com/galleries...cfm?gnum=10527
Also, how can I put the pictures directly on this post instead of linking to them? Damn newbies
Originally Posted by nooq
sweet. I noticed that the pro comp sits lower as well. I threw a 5" block in the rear of mine when i used to have just the pro comp with the spacer and it sat higher in the rear.
