help...bushings?
help...bushings?
alright i have a 98 f150.and here recently i just noticed that whenever i hit small bumps of even just backing out of my driveway im getting a squeaking noise coming from both sides of the front end..and i was thinking it was my bushings? just seeing if any of you guys ever had this problem..any help would be appreciated!
If it breaks at speed it would be bad. If it sqeeks when you turn, or go over bumps is a good indication that its a ball joint. Jack the truck up and let the wheel hang. Pull towards you on the bottom of the wheel. If there is play in the wheel you have a bad ball joint. They arent too bad to replace, if you have the tools to do it. Just make sure you get greasable replacement parts.
http://www.ford-trucks.com/forums/36...ght=ball+joint
