I added a 2.5" leveling kit to 2005. Now when I add 7 quarts of oil, it does not even mark the dip stick. Do I add more oil?
I have not had this problem and haven't heard of anyone else who has? It should not have caused a problem with your oil level. I would be careful adding oil and not to overfill before I ruled out other possibilites.
2005 XLT 5.4 Screw 4x4
Line-X, 2.5 AS and Superlift AAL, 305/50/20 Cooper Zeon LTZ's, 18" Magnaflow SI/SO, HD Grille, HD tails, A.R.E. tonneau, Edge upgraded with PHP custom tunes, K&N drop in, 35% tint, Kenwood KAC-6202, Kenwood KAC-8410D, Infinity Reference 6912cf, Alpine SPS-570A, RF Punch stage 1 8" in line-x box, Infinty perfect 10 DVC in Qlogic box .
I am happy that everyone has gotten as much use out of the write-up as it seems.
I'm kind of a write-up junkie on the various message boards I'm on because I really like showing how easy some of this stuff is to install yourself. I am not opposed to paying someone to do some things for me and I support local business when I can/need to, but I also support my pocket book, so I have learned to do a lot of things myself. I do lift installs 'on the side' for friends and customers so I can work through one of these installs swiftly. Leveling kits (coil spacers, strut spacers, etc.) are about as easy as they come. Most current trucks and SUVs have this same basic style suspension, so doing one is generally not much different than the next.
I will be doing this install again soon on my buddy's F-150 crew cab. I will also be doing the rear blocks, so I will likely add those steps just to make the writeup more complete. I think he is going to go with the 3" spacers as he has a 2wd, and does not have the same spring rate the FX4 does. The 3" spacers should compensate a bit for being a little lower from the start, and get him pretty close to the height of a leveled FX4, and room for 35s.
I install leveling kits in the Houston area - $125
TXST8tj, that would be awesome! I know that would help out a lot of people. BTW I don't know if I ever complemented you, but very nice write up!
3" PA Body Lift, 3" Level Kit, PC 1079 17x9,
BFG AT 315/70/r17, AIRAID CAI,
Flowmaster 50 SIDO 45 Degrees,
Hypertech Programmer My Truck
Well hell! Thanks for the offer neighbor!! I'll have everything together and be over at your place Saturday, 8:00 sharp!
I don't have anything yet, but hopefully I can swing a 4" Rancho by the wife sometime soon. I want to put bigger tires on the truck when I replace the OEMs that are on there now.
bill
2005 F150 4x4 SCrew Lariat 5.4l, Rancho 4", kd4crs/PH/Gotts intake, TCUSA American Roll Cover, WeatherTechs, Mark LT handles.
i never complimented you either for that i am dorry, if i didnt come by this well writen write up i would have never done this on my own, i did mine just last saturday and i swar to highhevans so far it is the best 120 iv ever spent on my truck.
i plan on using this write-up..
i do however have a question about the torque specs... since i dont have a tourque wrench, which kind should i buy, what should the range of the ft/lbs be?
thanks guys. will post pics when on!!
-LTZ
__________________ sig made by ME. im a graphics designer PM me and i can throw something together PerformanceAFE CAI, FM Super 40 SI/DO dumped, Hypertech Programmer Appearance: HBS 2.5" Level Kit, Aux Lights, MB Blitz, 285 75 17 BF Goodrich KO Sound: Infinity Reference 10" sub, Kicker 600w Amp, Rockford Fosgate speakers Wanted:black heads, tinted fogs and tails, led 3rd brake light, the list goes on and on
-LTZ
I don't know exactly what kind you would need, but Im sure that Advance Auto or a similar store would rent you one - and they should be able to tell you what kind you need
I believe the highest torque was for the lower strut bolt @ 225 ft/lbs. If you download the instructions a couples posts above it will tell you for sure.
