F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Powertrain & Mechanical > Suspension
Thread Tools Display Modes
  #91
Old 01-25-2009, 12:17 AM
Vehicle: 2008 Ford F-150
oh, and I don't think you can do both the keys and torsion twist, plus it would put a lot of stress on your front suspension... not sure tho
  #92
Old 02-16-2009, 08:07 PM
Vehicle: 2004 Ford F150
well, I attempted the install today but was unsuccesful, I couldn't break the ball joint loose with a hammer, the pitman arm puller i used was a little too small so long story short I used a pickle fork to try and seperate it and tore the boot around the ball joint, does anyone know if this part is readily available? Ill have to find the right pitman arm puller and give it another try another day.
  #93
Old 02-22-2009, 11:35 PM
Quote:
you may want to start a new thread on this if you havent already... but your best bet would probly be to buy another ball joint, either from the dealer or online... Moog has a good reputaion
  #94
Old 02-28-2009, 12:24 AM
I just finished my level on a 2wd with the 2.5 A.S. Level Kit following these directions, to make note of some of my issues It took about 2 hours 15 min to complete start to end. My first issue was i used a 15mm speed wrench instead of a socket for the spring bolts, second i didn't have the pittman puller so i used the hammer and it popped right off both sides, and lastly since it was just myself i used the floor jack to raise the a arm to the upper ball and that was about it. I did have the problem with the ball joints spinning top and bottom but without holding them i used an impact and it took care of it with no hassle. Thank you for the write up and i hope its as smooth for everyone else.
2004 F150 XLT SCAB White/Tan, 5%/20% Tint, Dual Exhaust, K&N Filter, 20" Maas Rims 285/55/20 BFG's
  #95
Old 03-01-2009, 07:11 PM
Vehicle: 2006 Ford F-150
Where did you get the kit from? I have an 06 FX4 supercab, and ive been wanting to do this, but i didn't know it could be done so cheep. Plus I was afraid my stock tires would look goofy, but it looks good on that truck. Nice job!
2006 F-150 FX4 5.4L V-8
  #96
Old 03-01-2009, 07:17 PM
Vehicle: 2006 Ford F150
Quote:
Heres a link to autospring's ebay store http://motors.shop.ebay.com/merchant..._ipgZ50?_rdc=1
  #97
Old 03-04-2009, 05:21 PM
Vehicle: 2005 Ford F150
Great Help!
I just wanted to say thanks for this post. I just installed a 2.5" AS kit on my truck and it couldn't have gone smoother. I probably could have done with the supplied instructions but the having more detailed info and pics made it a breeze!
  #98
Old 03-05-2009, 12:38 AM
HA HA. That help bring up my confidence and kinda scares me. Seems like alot of work that i'm about to get myself into. I will be putting my 3" on in a few days :?
+1 more vote to be a sticky
Sig Designed By: ltz400racer http://www.f150online.com/forums/mem...z400racer.html
2005 F-150 STX 4x2, 3" Hell Bent Steel Leveling Kit, Cobra Classic 23LTD, Black Widow 69" Antenna, DeflectaShield Challenger Black Low Profile Tool Box, Wild Country H/T 265/70R 17's
www.myspace.com/mims229
  #99
Old 03-07-2009, 09:23 PM
Nice work. I'll be using this in about a week. I'll be installing the ReadyLift 3" Level Kit (which is an identical install). My only concern is getting out of the garage....it's close as it is.
Opinions on rear level kits. Block or AAL? I'm leaning towards RL's 3" (which is actually only 1") Block lift.
  #100
Old 03-07-2009, 09:49 PM
hey would you mind taking some pics if the angles you have now afte the spacer
2005 f150 5.4 Dark Shadow Gray SCREW
Roush chrome over grill, magnaflow exhaust, 2" 4x4 blocks, tfx bed liner, K&N drop in
  #101
Old 03-09-2009, 11:45 AM
I just added a Superlift AAL. I wanted to go with the AAL instead of the block since I tow often. It was a pain the the butt to install but does look good and I notice little if any difference in ride quality. BTW if anyone here knows a good way to get the spring clips back in place let me know please! The good ole hammer and C clamps didnt do the trick. That being said if you are not towing alot the block would be much easier to install in my opinion. I think Fat Bob's makes a shorter leaf that you dont have to remove the factory clips so that might be a good solution as well?
  #102
Old 03-09-2009, 11:51 AM
Quote:
Here's mine after the 2.5" AS.
  #103
Old 03-09-2009, 02:18 PM
Has anyone noticed that the '04s, like the one this write-up was done on (I think) can have a 2.5" spacer and the CV is just a little off from being parallel to the ground? And that the later year model trucks can have a 2" spacer and be at more of an angle? Take for instance ab46501's picture and compare it to the OP's on the first page.
3" PA Body Lift, 3" Level Kit, PC 1079 17x9,
BFG AT 315/70/r17, AIRAID CAI,
Flowmaster 50 SIDO 45 Degrees,
Hypertech Programmer
My Truck
  #104
Old 03-09-2009, 03:45 PM
Quote:
I agree it looks more of an angle in my pic than the one of the first page. Could the angle of the camera be the difference? When comparing the angle to the strut it doesn't seem as much off? My sway bar attchment was also slightly different than the one on the first page. Maybe ford changed some things after 04?
  #105
Old 03-09-2009, 11:41 PM
Quote:
Im thinkin they changed up some stuff. I know when searching for lift kits the lift kit manufacturers make you select a different tab thing for Dec 04 - 08.... I don't know why... Surely they didn't change too much. I suppose the cv could appear to be different angles because of the camera, but take a look at the CV boot on either end. The OP's is still pretty flexible and almost straight, unlike yours and mine which is bent pretty good. Im just curious to know what's up with that.
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
