8 inch lift for 2005 4 x 2 F-150???
Hey F-150ers,
I have a question... I want to put 35.5 inch tires (Toyo) with 20 inch wheels but they dont make an 8 inch lift for F-150's 4 x 2.
I have already installed the leveling kit so couldn't I just install a six inch lift (Fab Tech) and ask them to send me 4 inch blocks for the rear instead of 2 inch? That would give me the extra height and keep it level to put The Toyo's I want!
Any ideas?
Any ideas?
Originally Posted by mannyahles
I thought about that. I have a 2 1/2 front leveling kit now. That why I thought about getting the FabTech 6 inch lift and requesting 2 inch longer blocks for the rear. Then I would just leave the 2 1/2 inch kit on in the front. That would give me at least 8 inches
if you get the cst you can say you have a CST and be way more badass instead of saying i have a fabtech like everyone else.... (not bagging of fabtech) i dont understand why you think you can't run 20's with the CST aswell... where did you get that idea?
I have been asking around and I have been told that the 6 inch lifts only work if you use an 18 inch wheel and it cant be that wide...maybe 8 inches or 9 max. Otherwise you have too much rubbing even with a lil trimming.
20-22 inch wheels on Toyo mud are 35.5 inch tall and a bit wider so that would even rub a bit more than just a 35.
how wide is the tire you are wanting to run and whats the backspacing the wheels aswell?
That is great news. I happen to have Diamo 12 Karat 20 inch wheels on my truck now. I am going to take my truck into Discount and have my tires rotated. I will ask them about the back spacing. This exact style wheel is not in production so I cannot find any info on them nor on the company.
WHich members trucks are running 20-22's on their trucks with 6 inch lift so I can check em out!
Thanks for your input and help!
I am afraid that if I put the 6 inch fabtech along with the existing 2 1/2 inch leveling kit then I would be too high in the front as compared to the rear. Fabtech lifts the front more than the back to even out the truck...maybe make it ride a skosh higher in the front. Thats why I think I'll need to request taller blocks in the rear.
