Need Help!!
Need Help!!
i have an 02 Screw bagged on 22"s. has anyone bagged a Screw on here yet?ive seen a few at some shows around the state. i need to know if theres anywhere i can get aftermarket crossmembers or something. my driveshaft WAS hitting my gastank crossmember till i cut it out and it is now hitting the crossmember just behind the tranny when i lay it out. any ideas/info would be greatly appreciated! thanks- joe
additional info about truck:
Kpcomponents 6 link rear suspension set-up
1/2" valves and 1/2" hydrolic lines
5gallon air tank
2 ViAir 480 compressors
RE7 bags on all corners
Full 02 navigator front clilp
HID headlights and fog lights
22" ICE METAL wheels
5gallon air tank
I haven't put bags on my truck yet, but I put an 8" notch in the frame and ran the axle threw it's range till it layed on the ground. And I found that the driveshaft will hit the rear cab cross member long before it makes it to the ground. So I found a driveshaft fabrication place, and had them make me a drivershaft with a midshaft bearing, a 7" slip yolk, spicer U-joints, and smaller 3" diameter tubing. All they used is the front yolk, and rear yolk plate. And it works perfect without cutting any cross members! But it cost me $450 to have it made (well worth it in my opinion).
