Quick question before coilover install...
Hows it going. Just wanted to clear this up so i can keep myself somewhat safe from the OEM coilspring.
Now, with the truck at full droop in the front, if i unbolt everything needed to remove the coil/strut assembly, is that spring going to be under any load and will it pop on me? or is it compressed within the top and bottom coil hats, and should just slide out with some effort? thanks guys.
Your not going to have to worry about the spring flying out. All you will be doing is taking out your old coil strut and the 6inch pro comp spacer and replacing them with the dirt logics. The stock coil/strut won't be reused and you won't have to worry about the load cause your not going to be taking the stock coil/strut apart.
I had no problem when I pulled mine out as long as the suspension is at full drop you should be fine. Is it possible to replace the coiloever without separating the ball joints from the spindle and removing the spindle? Im considering doing the same installation but I dont feel like going through all that work just yet. I just put my lift on about a month ago.
That's all your gonna need to do. Remove the 30mm nut holding the coil on the lca, remove the upper ball joint from the spindle, remove the sway bar nut and remove the 3 nuts holding the coil/strut and it should come out with some twisting and moving around. Then just put the dirt logics in and reverse the order.
I haven't had problems ripping the boots but my brother ripped one, was a tiny rip, maybe 1/4 inch, I think he used some super glue to try and patch it up till he could replace them. they have been holding since. I believe your looking at around $1100 for the dirtlogics, that's what 4wheelparts priced me.
just down load the instructions for a AS leveling kit.... the only differance is your putting in a new coilover, they will be perfect for your install. oh and you may want to get yourself a gear puller or a big *** sleg hammer for when you seperate the UCA form the spindle.
should have used a gear puller, $3 at harbor Freight.
When I separated my ball joints last time around I destroyed the boots and ended up replacing all my ball joints to be safe.
