Daystar Install Question
Thanks for the reply. I figures so but wanted to make sure before I got it all apart. I will just have to locate a spring compressor now.
By installing just the top part, that is a 1" lift correct?
What is the quality of safety and strength of the one that bolt onto the spring and then bolt onto your truck? Wouldnt they start to creak over time? I dont want to over extend my ball joints either, and when I go offroad, I dont want the suspension to be topping out all the time. That is why I only want ot go 1", this will be to eliminate the rubbing.
Thanks for the replies.
Can you remove the srping with just a standard spring compressor?
Also, my truck seems to "creak" sometimes, is that just the Fabtech drop rubbing against the frame where it bolts up? Usually when I back up and say put the brakes on firm, or when going out of driveways sometimes.
