Quote:
Originally Posted by Impact9
Before you go and dump money on shocks check the prices to get your brake lines extended or replaced. I've got the pro comp 6" lift also and I don't see it being very safe adding another 2.5" of lift to this. If you do check the prices please post your estimates.
Impact, when my truck is on the lift with the front tires off the ground, my brake lines are fine. Only thing that seems to be on the side of being stretched is the vaccum lines for 4WD. Unless the spacer or shocks can extend it beyond what it is with the tires just hanging in the air, which it can't, I should not have a problem.
Only thing that I have to price besides the shocks or just putting on my spacer, is to get it aligned again.
