Go Back   F150online Forums > Powertrain & Mechanical > Suspension
Sign in using an external account
Register Forgot Password?
Register Photos Vin Decoder FAQ Members Search Today's Posts Mark Forums Read VendorsGarage
Suspension SPONSORED BY:
Thread Tools Search this Thread Display Modes
Old 06-11-2007, 11:02 AM
Garage is empty, add now
RCD Lift Kit
Is anybody running this lift in there 97-03 F150 if soo can you post some pictures and also would i be able to run the Rancho 4" lift and clear 35's
Old 06-11-2007, 12:34 PM
Vehicle: 2001 ford f150
Several members at FTW have the RCD kit. As for 35's, you can fit them with the Rancho kit also.
2005 Expy, 305/45-22 Falkens on 22x9.5 Eagle 026s.
2011 Jeep Wrangler Unlimited, 2" lift, 33" BFG AT KO's on 17x9 Eagle 197s.
2012 Ram 2500 crewcab diesel. 5" RCX lift, 355/60-20 Nitto Terra Grapplers on 20x9 KMC XD Spys.
Old 06-11-2007, 06:57 PM
Please Help
I want to clear 35's...and i do not know which kit will be better. Rancho or RCD...also are both of the kits bolt on? can you guys please give me some feedback
Old 06-11-2007, 07:35 PM
The RCD kit is a little higher quality than the Rancho ( but there is nothing wrong with the Rancho). I'm not sure if cutting is required.
Old 06-11-2007, 10:47 PM
Vehicle: 2001 Ford F-150
I've talked to my local offroad shop and they said the RCD kit is one of the best for the 97-03 models. For a supercrew with the RCD lift a little cutting will be required to fit 35's.
Old 06-12-2007, 10:11 AM
Send a message via MSN to keith_bennett Send a message via Yahoo to keith_bennett
Rancho lift requires no cutting. Compltete bolt on. You might have to trim the lower valance to fit the 35's.
Old 06-13-2007, 09:00 PM
Vehicle: 1999 Ford F-250
Rcd
I'm thinking it mostly depends on the wheels and tires you want to run. There are alot of guys running 35" tires with a 3" bodylift. And there are alot of guys running 35" tires with a 6" susp. lift. So the 4" Rancho and the 5" RCD should clear 35" tires just fine. As for trimming needed, maybe a little with the Rancho, but not near as much if any with the RCD.
I myself ordered a set of 315/75/16 Hankook MTs and will be putting them on a 16x10 wheel with a 3" bodylift. But I won't WHEEL it very hard, mainly going places hunting and fishing where I want a little more clearance and tire to get around.
Shane
Old 06-21-2007, 08:55 PM
2002 Ford F-150
Vehicle: 2002 Ford F-150
I have the 6 "RCD kit on my 02' although mine is only a 2wd. I'm only running 33" tires as of now but next I will get 35's. I'd have to say the 35's would fit easily with my kit and no trimming would be needed at all. I have my stock rims with 4.5" of back spacing if that helps any.
- Chris
02' F-150 XLT Sport | 4.2L | 4x2
6" RCD lift | 4.56LS | RCD rear traction bars
Troyer Tuned XCAL2 | AF1 intake
285/70/17 BFG AT KO's
Old 06-21-2007, 09:48 PM
Vehicle: 2005 ford f150
here is my buddys truck 03 4x4 6" rcd 35" tires.
Click the image to open in full size.
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are Off
Pingbacks are On
Refbacks are Off
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company
Emails & Contact Details
Search Engine Friendly URLs by vBSEO 3.5.2
