Go Back   F150online Forums > Powertrain & Mechanical > Suspension
Sign in using an external account
Register Forgot Password?
Register Photos Vin Decoder FAQ Members Search Today's Posts Mark Forums Read VendorsGarage
Suspension SPONSORED BY:
Thread Tools Search this Thread Display Modes
Old 09-25-2006, 03:27 AM
Garage is empty, add now
Leveling a 2002 screw fx4..
Any way to do this? There are no coil springs, and I don't see what I can tighten to raise the front end? Not really interested in a body lift right now though, wouldn't level the ride anyway. Any help would be appreciated, especially with pics! Thanks!
Old 09-25-2006, 03:45 AM
Vehicle: 2010 Ford F-150
Send a message via AIM to russ10screw
crank the torsion bars
I have the same model truck. You have to crank the torsion bars to raise and level the front end.
2010 SuperCrew FX4 * 5.4L V8 * 3.73 * Nitto Trail Grapplers - 295/60/20 * XD Monsters - 20x9 +18 offset * 1.5" AutoSpring Level * Line-X Bedliner & Step Bars * Harley Heads and Tails * Black Billet Grille * Borla ProXS 40349 * S&B CAI with Ram Air Scoop * 5Star Tuned SCT X3 Tuner * Polk MM6501's, Polk MM571's, JL 10w1v2-4, AudioControl LC7i, JL XD700/5
Old 09-25-2006, 03:48 AM
Quote:
I have to admit I don't know what to tighten.... any pics? It would be apreciated!
Old 09-25-2006, 06:38 AM
Vehicle: 1997 Ford F150 4x4
do a search, or even look down 1 or 2 pages of this forum. Plenty of info on it.
'02 F250 Lariat CrewCab, 4x4, 7.3L PSD
My Gallery
Old 09-25-2006, 07:52 AM
Vehicle: 2001 ford f150
Here's a pic of one of the torsion bars, the adjustment cam and the bolt. The torsion bar is the long round bar, the adjustment key is covered in surface rust. There is one on each side of the truck. Just turn each adjustment bolt an equal number of turns. Don't forget to get an alignment afterwards.
Click the image to open in full size.
2005 Expy, 305/45-22 Falkens on 22x9.5 Eagle 026s.
2011 Jeep Wrangler Unlimited, 2" lift, 33" BFG AT KO's on 17x9 Eagle 197s.
2012 Ram 2500 crewcab diesel. 5" RCX lift, 355/60-20 Nitto Terra Grapplers on 20x9 KMC XD Spys.
Old 09-26-2006, 10:33 PM
One of the bolts has about 5/8" showing the other about 3/8"... can I turn them all the way in? It still sits pretty low, will it do much? Maybe I will have to rethink the body lift sooner.. but it will still be stinkbugged.
Wandell- How did you get yours to sit as level as it is?
Thanks for the replies!
Old 09-27-2006, 07:57 AM
Trick photography! Mine is a little nose low, the pics just make it look level. It's not unusual for the two bars to have different amounts of preload. I would crank them both an equal number of turns. When you have it aligned, ask the tech if he can crank the other one up and keep the alignment within specs.
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are Off
Pingbacks are On
Refbacks are Off
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company
Emails & Contact Details
Search Engine Friendly URLs by vBSEO 3.5.2
