Go Back   F150online Forums > Powertrain & Mechanical > Suspension
Sign in using an external account
Register Forgot Password?
Register Photos Vin Decoder FAQ Members Search Today's Posts Mark Forums Read VendorsGarage
Suspension SPONSORED BY:
Thread Tools Search this Thread Display Modes
Old 09-18-2006, 01:21 PM
Garage is empty, add now
Vehicle: 2006 Ford f150
Skyjacker lift with leveling kit
I am looking at getting a 3" skyjacker lift kit, along with a 2" leveling kit for my 2wd 2006 f150. I was wondering if it's possible to even install these two together, and if so, would i need to change out any springs, shocks, or anything else or would this be it? If so, would this raise the front 5" and the back 3" or would there be some sort of difference? I am new to the lifting part of trucks, and not sure how different parts work with one another, so sorry for the simple questions.
Would this change the ride quality either or put any uneeded stress on the struts or shocks of the truck or would everything underneather be in shape? Thank you all.
Old 09-18-2006, 04:08 PM
Vehicle: 2001 ford f150
No you can't install both. Your ball joints will be at way too severe of an angle with both. I'd just go with a 2.5 inch leveling kit. You could add a 3 inch body lift if you are trying to keep cost down.
2005 Expy, 305/45-22 Falkens on 22x9.5 Eagle 026s.
2011 Jeep Wrangler Unlimited, 2" lift, 33" BFG AT KO's on 17x9 Eagle 197s.
2012 Ram 2500 crewcab diesel. 5" RCX lift, 355/60-20 Nitto Terra Grapplers on 20x9 KMC XD Spys.
Old 09-18-2006, 04:43 PM
Thanks. Now what if i just did the 3" suspension lift instead of leveling, only because i think i can get the lift at a very inexpensive price through a friend and it raises the truck up more and raises the back as well, but will this cost a large amount to install? The skyjacker has shocks and springs for the front and add-a-leaf for the back but the problem with adding this over the leveling kit is i want a level look and its a lot cheaper for almost the same height, the only reason i would do the skyjacker over body lift is for cost but if i cant do skyjacker with the leveler that eliminates that option. thank you and let me know.
Old 09-19-2006, 07:53 AM
A couple of members here and FTW have had the Skyjacker lift and removed it. There must be a reason everyone else limits their lifts to 2.5 inches. An Autospring leveling kit and a taller lift block for the rear is still much cheaper
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are Off
Pingbacks are On
Refbacks are Off
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company
Emails & Contact Details
Search Engine Friendly URLs by vBSEO 3.5.2
