Rear Leaf Spring Squeak
More than likely 1 or more of the teflon spacers between the ends of the springs are worn out allowing metal to metal contact. Thas what was happening to my '99 4X4, went to Ford dealer and got 2 or 3 packs of spacers so I would be ready for the next time it happens. Now if I could just find a cure for the tailgate squeaks!!!!!
You Can Buy The Spacers If You Want, There Not Very Expensive At All. I Work In Automotive And When I See That Problem With Customer's Truck, All I Do Is Use A Prybar To Pry The Leaf Springs Apart Right Where The Second And Third Spring From The Bottom Meet At The End And Squirt Some Tube Grease Or Wheel Bearing Grease In Between. (watch Your Fingers) This Will Stop It For 6 Months Or Less.
