Go Back   F150online Forums > Powertrain & Mechanical > Suspension
Sign in using an external account
Register Forgot Password?
Register Photos Vin Decoder FAQ Members Search Today's Posts Mark Forums Read VendorsGarage
Suspension SPONSORED BY:
Thread Tools Search this Thread Display Modes
Old 02-27-2006, 08:04 PM
Garage is empty, add now
Vehicle: 2001 Ford F-150
Send a message via Yahoo to 3304x4
simple question not so simple answers
I was wondering if it would be possible to swap an f-250 suspension into an f-150 for more payload capacity? I know I should have just bought an f-250, but that isn't an option. My question is if I could find an f-250 in a junk yard would it be possible to swap out the suspension, and front and rear diff?
Old 02-27-2006, 08:48 PM
Vehicle: 2006 Ford F150
Send a message via AIM to Bartak1
If you found a F150 7700, all that stuff should bolt right up. If your talking the suspension from a Superduty, then no, I dont think you could get that to fit w/o major modification. A light duty F250 should bolt right up too.
Troyer Tuned-3.5" AF1-Magnaflow SI/DO
Eclipse CD 8053
Rainbow Profi Vandis, active
Arc Audio 4050XXK
15" SI Mag, 2.5 sealed
Arc Audio 1500XXK
Old 02-27-2006, 09:47 PM
Thanks for the info.
Old 03-01-2006, 02:46 PM
Vehicle: 2000 Ford F-150
Send a message via AIM to GIJoeCam Send a message via Yahoo to GIJoeCam
Ditto. The 7700 lb parts should bolt right up. You will also need the 7-lug wheels off it as well. In addition to the rear axle, I woud replace the front hubs, brakes, and torsion bars as well.
-Joe
'00 F-150, X-cab, 4x4, Lariat, 5.4L Off-road, Trailer Tow, Holandia Sunroof($1000)Mucho mods
98 Explorer bone-stock (Lemon Law Case in Progress)
Photo Gallery Here
I'm not smart, just a resourceful idiot with some spare time.
Old 03-01-2006, 05:46 PM
Thanks, I was gonna try and find a front and rear end with tires still attached. I didn't think about the torsion bars.
Old 03-01-2006, 05:53 PM
The frames are different.
Old 03-02-2006, 09:01 AM
Quote:
Not for an '01, I don't believe. Can't say for sure. At any rate, the rear suspension is a direct bolt-in, and the front suspension components are the same, save for the hub assemblies.
You could probably still get away with the original torsion bars anyways. Unless you're looking at mounting a plow, it'll probably be fine.
-Joe
Old 03-02-2006, 09:49 AM
Vehicle: 1997 Ford F150 4x4
The only difference I've heard of on the F250LD and the F150 is the suspesion and brakes, among some other slight things...but nothing as major as a frame.
I've seen quite a few of the SuperCrew guys run the 7700lb torsion bars by simply moving their crossmembers back (the frame already has the proper holes in it for this).
'02 F250 Lariat CrewCab, 4x4, 7.3L PSD
My Gallery
Old 03-02-2006, 12:53 PM
Searching the archives will bring up numerous confirmations, so does all of Ford's literature.
7700-lb. Payload Group A (627)
• Upgrades Styleside 139-inch WB
Regular Cab and SuperCab GVWR to
7700 lbs., for increased payloads and
towing. On 4x4 only, includes front
GAWR of 4150 lbs. to accommodate
a snowplow
•Includes larger brakes, higher capacity
16-inch 7-lug wheels and LT245 tires
4x2 all-season (T34); 4x4 all-terrain
(T3P), heavy-duty frame, heavy-duty
shock absorbers (4x4) and springs
• 72 amp.-hr. battery, upgraded radiator
(1.42-inch core thickness) and auxiliary
transmission oil cooler (14 plate)
• 4x4 includes snowplow capability;
no separate snowplow prep required
or available
• 3.73 axle ratio
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are Off
Pingbacks are On
Refbacks are Off
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company
Emails & Contact Details
Search Engine Friendly URLs by vBSEO 3.5.2
