02-27-2006, 03:51 PM
Your ride will be a lot worse. Basically the whole reason behing IFS is improved ride and handling. For what you want to do, you would be much, much better off to buy a Super Duty. Even if you do a straight axle conversion, the rest of your drivetrain is still half ton components.
2005 Expy, 305/45-22 Falkens on 22x9.5 Eagle 026s.
2011 Jeep Wrangler Unlimited, 2" lift, 33" BFG AT KO's on 17x9 Eagle 197s.
2012 Ram 2500 crewcab diesel. 5" RCX lift, 355/60-20 Nitto Terra Grapplers on 20x9 KMC XD Spys.
02-27-2006, 05:18 PM
Garage is empty, add now
Vehicle: 2003 Ford F-150
Quote:
Originally Posted by 97on37s
How will my ride be effected if I change from a IFS to a stright axle on my 97 F-150? Also is it worth doing? I want to go to a 12in lift and a 3in body lift with some 44in tires.  wanted.
if done right then it could ride nice, but there is no bolt on kit currently avalable that is worth a damn for a SAS on these f-150s, it would take alot of time and money and fabrication to do a very good SAS that rides nice and wont cause other problems in the powertrain, i am going to do one in a few years on my 03 when it is not my daily driver, i expect it to take 6 months of fabrication to get it all perfect, good luck
 03 F-150 5.4 FX4 with HD supercharger swap at 10PSI, 6" fabtech with PA 3" body lift, 38"15.5" MT Baja claws, on 16" 10" extreem aloys, fabtech steering stabilizer, procomp traction bars, pro comp add a leaf, cranked torsion bars,4.88 gears, detroit locker in rear, ARB locker up front, troyer E-fans, X-cal 2 tuned by Sal, FTVB shift kit, on board air system, TONS OF CUSTOM MODS, AND ONE UNSTOPPABLE BEAST
02-27-2006, 07:28 PM
I talked to a guy at a car and truck show this weekend that had a (i think) 2002 chevy. He had converted from a IFS to a stright axle and said it rides better than before so that is why I want to know. Would it make a difference sense it was a chevy and not a Ford?
02-27-2006, 07:47 PM
Vehicle: 1997 Ford F150 4x4
Chevy vs. Ford has nothing to do with it in this case, its all in the quality of the work and the research that goes into it. If the design and fabrication processes arent done properly, its going to ride like crap, regardless of whether the truck is a Ford, Chevy, Dodge, Toyota, etc.
'02 F250 Lariat CrewCab, 4x4, 7.3L PSD
My Gallery
02-27-2006, 08:42 PM
ok thanks
02-27-2006, 09:21 PM
Are 2002 Chevys IFS?
02-27-2006, 09:45 PM
Quote:
yep
02-28-2006, 08:01 AM
Yes.
02-28-2006, 09:34 AM
Half-tons (and, I think 2500's) since 1988; 3500's since 1988 or '89
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is On
