Go Back   F150online Forums > Powertrain & Mechanical > Suspension
Sign in using an external account
Register Forgot Password?
Register Photos Vin Decoder FAQ Members Search Today's Posts Mark Forums Read VendorsGarage
Suspension SPONSORED BY:
Thread Tools Search this Thread Display Modes
Old 02-12-2006, 04:10 PM
Garage is empty, add now
Vehicle: 1993 Ford F-150
tighten torsion bars...
hey im not really familiar with suspension, but i would like an inch or 2 more so my 31's will not be so tight with the fender. I heard tightening the torsion bar will give me what i want, but there must be some reason its set at what it is. So, what are the consequences of doing this and how much will it cost?
Matt S.
1993 Ford F-150/5.8L V8 351 Windsor/Short Bed/Alloy Wheels/Magnaflow Catback/Goodyear Wrangler HT 31x10.5's /Leer Bedliner/ProTint Windows
Old 02-12-2006, 04:19 PM
1967 Chevrolet Camaro
Vehicle: 1998 Ford F150
Cost: Free
Consequences: If you go too much, theres the possibility of prematurely worn parts, ball joints suffering the most. I've had mine cranked for that last 80,000 miles, and the drivers side ball joint just started sqeaking...
98 F-150 4x4, 4.6L
Custom Intake & Airbox mod
Toyo Open Country 285/70/17's
Custom Reverse Lights
More to come...
Old 02-12-2006, 07:48 PM
Vehicle: 2001 ford f150
1993 F-150's don't have torsion bars.
2005 Expy, 305/45-22 Falkens on 22x9.5 Eagle 026s.
2011 Jeep Wrangler Unlimited, 2" lift, 33" BFG AT KO's on 17x9 Eagle 197s.
2012 Ram 2500 crewcab diesel. 5" RCX lift, 355/60-20 Nitto Terra Grapplers on 20x9 KMC XD Spys.
Old 02-12-2006, 08:47 PM
Quote:
HaHa... I never looked. I assumed since he asked, he had them (on a later model truck, of course). Never even seen the '93'...
98 F-150 4x4, 4.6L
More to come...
Old 02-21-2006, 08:18 PM
Vehicle: 1997 Ford F250 LD
So if you tighten the torsion bars you can get some lift out of the front end? I have a 97 F250 LD, and was looking to fit 33inch tires on it. Would this help clear those tires?
Old 02-21-2006, 08:34 PM
Vehicle: 1997 Ford F150 4x4
Well if your truck is a 4x2, you dont have torsion bars, you have coil springs, and in that case youll need to use a spacer to get some lift
If you do have the 4x4, yes, you can crank the torsion bars, but 33"s should fit even without cranking, depending on how wide and what wheels you are using.
'02 F250 Lariat CrewCab, 4x4, 7.3L PSD
My Gallery
Old 02-21-2006, 09:36 PM
Vehicle: 1999 Ford F-150
When and if you ajdust the torsion bars, you will need to have the truck aligned. Just remember that an alignment is alot cheeper than 4 new tires.
Alignment & Brake Tech
99 F-150 NASCAR - stock
73 Nova - oops not a Ford
80 gallon salt water aquarium - stress reliever
Old 02-26-2006, 01:41 PM
Thanks guys. My truck is a 4x4. Of course I have the year..97... that Ford decided to put 7 lugs on the axles, so my wheel choice is very limited. If i use stock rims, which are 16x7, the 33's should fit right?
My other choice is to go to a 17" wheel, which gives me a little more choice of rim, but they are expensive.
Old 02-26-2006, 02:41 PM
2005 Ford F-150
Vehicle: 2005 Ford F150
You shouldn't have any fitment problems with 33" tires on stock suspension. I've got 33's on my 98 1/2 ton 4x4 and have never had any issues.
Old 02-26-2006, 02:55 PM
Yes 33"s will fit fine, you could put a 305/70R16 on there with some minor trimming of the valence.
My Gallery
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are Off
Pingbacks are On
Refbacks are Off
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company
Emails & Contact Details
Search Engine Friendly URLs by vBSEO 3.5.2
