Go Back   F150online Forums > Powertrain & Mechanical > Suspension
Sign in using an external account
Register Forgot Password?
Register Photos Vin Decoder FAQ Members Search Today's Posts Mark Forums Read VendorsGarage
Suspension SPONSORED BY:
Thread Tools Search this Thread Display Modes
Old 05-23-2005, 07:44 PM
Garage is empty, add now
Vehicle: 1997 Ford F-150
R&R Rear Shocks
I know I am missing something here - but I do need some help.
I am removing and replacing my OEM shocks on a '97 F-150, Lariat, ext, 4WD. I have gotten the front ones replaced, but CANNOT get the rear shocks to come off. I have still got the lower portion through bolted into the frame saddle, but when I attempt to turn the top bolt (bwtn the bed and frame rail) off, it will NOT loosen. I have tried holding the plastic dirt sleeve as it does want to turn, leading me to believe that the spindle itself is turning. Unlike the front set w/an upper and lower bolt (one to hold while loosening the other) I cannot locate such a configuration on the rear.
Are there any secrets or tips for this? I would just as soon put a pair of vise grips to the top spindle to prevent turning (as it goes away w/the old shock) but then I am prevented from accessing it w/a socket.
Any advice/help here is most appreciated.
Old 05-24-2005, 09:50 AM
Vehicle: 2000 Ford F-150
Send a message via AIM to GIJoeCam Send a message via Yahoo to GIJoeCam
hen I took mine off, I had the same problem. Yank that plastic dust sleeve off and grab the shaft with a big honkin' pair of pliers. It doesn't matter if you scarf up the shaft since you're gettin' rid of them anyways.
-Joe
Old 05-24-2005, 12:57 PM
JMC JMC is offline
2000 Ford F-150
Vehicle: 2000 Ford F-150 4x4
Send a message via ICQ to JMC
What Joe wrote. That is how I do mine.
JMC
Regards
Jean Marc Chartier
4.6 to 5.4 swap, M5OD w/ Hurst short throw, Warn XD9000i, OBX Long Tubes /w Cats, Troyer E-fans, P-1SC Procharger @15psi, Troyer tuned. ;)
Swap notes; http://www.f150online.com/forums/art...ml#post3570245
Old 05-24-2005, 01:13 PM
Vehicle: 1998 FORD F150
also use some pb blaster. The nuts will come off easier.
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are Off
Pingbacks are On
Refbacks are Off
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company
Emails & Contact Details
Search Engine Friendly URLs by vBSEO 3.5.2
