Go Back   F150online Forums > Powertrain & Mechanical > Suspension
Sign in using an external account
Register Forgot Password?
Register Photos Vin Decoder FAQ Members Search Today's Posts Mark Forums Read VendorsGarage
Suspension SPONSORED BY:
Thread Tools Search this Thread Display Modes
Old 05-02-2005, 08:31 PM
Garage is empty, add now
Vehicle: 1995 FORD F150
help with a clunk!!!
Okay here goes. Vehicle is 1995 Ford F150 4WD SB Reg Cab 5.0L. 3" body lift and 4" Suspension lift. 35" tires. While turning steering wheel to the left there is a pronounced "clunk". While turning back the other way...same clunk. While not turning wheel and moving forward and applying brake...same clunk...stop move backward and apply brake...same clunk. Its like a burr or hang up some where. We watch the front suspension closely and can see nothing move. Someone said they saw the front differential jump a little. The clunk is not very loud and does not happen all of the time. Could this be in the front axle?...Ant thoughts would be appreciated.
ww
Old 05-02-2005, 11:36 PM
Vehicle: 1997 ford f150 4x4
B b b b ball joints.
Mac cold air intake
Magnaflow si/do 2.5 to 4inch magnaflow slash cut tips
285/75/16 high-tech retreads(love em)
Roll n lock bed cover
Fogetabodit
Old 05-03-2005, 12:00 AM
Ball joints are all new with no movement
Old 05-03-2005, 08:01 PM
Jack up the front and support the vehicle(heavy duty jack stands). Have someone sit in cab while you r under truck. Start grabbing steering linkage while someone is turn the wheel whith the truck off and with the truck on. You may feel or see where the clunk is coming from.
Mac cold air intake
Fogetabodit
Old 05-03-2005, 08:05 PM
Just thought of something, 95 had the TTB with coils. Depending on the lift manufacturer, depending on how the diff was dropped, go around with the truck still in the air and retighten all the suspension attachment bolts. I actually had this problem on my 91 f150 with a Ranch 6 inch kit. Hope this helps.
Old 05-06-2005, 01:45 AM
Vehicle: 1995 Ford F-150
Check your radius arm bushings. Also, just because the b-joints are new dosn't mean anything. They can go 10 miles or 100,000 (though rare, but you get the point).
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are Off
Pingbacks are On
Refbacks are Off
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company
Emails & Contact Details
Search Engine Friendly URLs by vBSEO 3.5.2
