04-26-2005, 01:26 PM
shocks for f150 2002
I have a FX4 supercrew and probably need to replace the shocks. I have the Rancho's now.. are there any alternatives to these that are reasonably priced. I would need shocks and install.
04-26-2005, 03:01 PM
Garage is empty, add now
Vehicle: 2003 Ford F-150
how will you be using your truck? on road off road what is your price range? looking for stiffer ride less body roll need to go alittle more in depth to give a better anwser
 03 F-150 5.4 FX4 with HD supercharger swap at 10PSI, 6" fabtech with PA 3" body lift, 38"15.5" MT Baja claws, on 16" 10" extreem aloys, fabtech steering stabilizer, procomp traction bars, pro comp add a leaf, cranked torsion bars,4.88 gears, detroit locker in rear, ARB locker up front, troyer E-fans, X-cal 2 tuned by Sal, FTVB shift kit, on board air system, TONS OF CUSTOM MODS, AND ONE UNSTOPPABLE BEAST
04-27-2005, 09:47 AM
drive mostly on the road, but do go off from time to time when snowmobiling or camping. But looking for better handling that is not so soft that it makes the truck less able. Do you know what i mean? but i want something that doesn't ride like a dump truck over man holes like it does now.. the current shocks have 86k on them.
not sure what i should be paying, i have never priced out shocks but i hear the rancho's are over $100 each..
04-27-2005, 11:27 AM
Order these RS9000x, call a buddy and you''ll be done in 2 hours.
04-27-2005, 11:48 AM
Good advice..
Hi. Good advice from APT.
If you do go this route, read this thread first ( and don't forget the bushing lube ;-))
Rancho 9000X: Disappointed!
In addition, while out chasing down the lube, pick up a case of cold ones - that will ensure an abundant supply of buddies to help you!
Good luck and cheers!
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is On
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company |
