all lifted 97-03 show us a pic
Old 03-29-2005, 07:13 PM
bigtruck311's Avatar
Talking all lifted 97-03 show us a pic
saw this in the 04-05 forrum thought it would be cool to show off all the lifted trucks(gives me a reason to show mine off too) pic and how much lift you got
around 11" of lift totall
Old 03-29-2005, 07:57 PM
wandell's Avatar
Old 03-30-2005, 12:04 AM
Philford's Avatar
4" Trailmaster suspension/4" body lift
Old 03-30-2005, 12:40 AM
ruffn-it's Avatar
5in fabtech. Yea I know, it's a 2wd.
Old 03-30-2005, 12:47 AM
S'crew'n'03's Avatar
3" and 35's
Old 03-30-2005, 01:28 AM
FLAMETIP's Avatar
1999 F150 2WD 7.5" Fabtech lift 3" body lift
Old 03-30-2005, 11:12 AM
Hey Bigtruck. Question. We have talked before but I have a question for you. I have a 97 f150 and it is about the same set up you have. I have a superlift on mine. I am running 38x12.50. I want to run wider but cant because I only have about eight of an inch clearance between the back sidewall of the tire and the spindle. How did you fit those monster 15.50 on your truck cause it looks tight. My tires just look tall not wide. Thanks for you help.
Old 03-30-2005, 11:25 AM
Kurt_02F150's Avatar
diff backspacing??
Old 03-30-2005, 12:47 PM
16-10 rims with 4.5" backspacing, had to trim the front valance, and cut a peice from the lower controll arm and the e brake cable in the drivers side rear had to relocare the bracket, but other than that perfect fit, if you need to know more i got pics
Old 03-30-2005, 01:49 PM
I think I have the exact backspacing and can only fit 12.50's I hope to have some pictures up on here of my baby later today after I wash her cause it is suprisingly nice here in Indiana. The local tire shop suggested i get some reverse backspacing wheels
Old 03-30-2005, 04:58 PM
exactly were was it going to rub? you should be able to fit 15.5 if you have the same set up as me, are your torsoin bars cranked? i would make sure you have 4.5" of backspacing
Old 03-30-2005, 07:08 PM
it is going to rub the spindle on the backside of the tire. It isn't about height. It clears fine. I do not have a quarter of an inch of clearance between the back of the tire and the superlift spindle. So anyhow, I have brand new tires so it will a while before i get wider ones. Anyhow, here are some pictures of her finally.
[IMG]C:\Documents and Settings\Owner\My Documents\My Pictures\New\Truck 2.JPG[/IMG]
[IMG]C:\Documents and Settings\Owner\My Documents\My Pictures\New\Truck 4.JPG[/IMG]
Old 03-30-2005, 07:10 PM
well i guess i am stupid and can't figure out how to post pictures.
Old 03-30-2005, 07:51 PM
you have to put them in a gallery here at this site and us the url tags that the gallery provides
Old 03-30-2005, 07:52 PM
if you can show me a pic of were it is close to rubbing
Quick Reply: all lifted 97-03 show us a pic
