all lifted 97-03 show us a pic
Old 03-30-2005, 08:10 PM
I will get a picture of the truck up tonight. I don't have one of the spindle. It is close to rubbing the spindle that connects the upper and lower control arms. Earlier this year I had the ball joints go bad on the passenger side and the top of the tire was actually rubbing the spindle. I could smell rubber burning and there was this ring around the inside of my old tire.
Old 03-30-2005, 08:12 PM
Southern-Fx4's Avatar
learning to post pics haha
35x12.5x17 bfg mudders on stock fx4 rims 6" fabtech
So the future georgia tech student isn't a retard after all haha.
Old 03-31-2005, 10:54 AM
bigtruck311's Avatar
blackflareside, just to be clear we are talking about a 4x4 right? if it is a 4x4 i think it might be your lift, or maybe your backspacing, do you have 10" wide rims?
Old 04-01-2005, 12:17 PM
yeah, it is a 4x4 with a 5 inch superlift and 3 inch body lift with add a leafs and the torsion bars cranked all the way. got about 10 inches of lift. I have 16.5x9.75 wheels. Not sure on the backspacing. Still trying to get pictures up. Right now the drive shaft is laying in the back of my bed. Did a burn out last night in the parking lot for all my friends. I was spinning those 38's pretty good when the rear yoke on the differential broke. So that is my latest project. SHould have it back together in a couple of hours.
Old 04-01-2005, 12:25 PM
not familair with the superlift, but i think it is your backspacing, 4.5 is what you will need to run 15.5" tires, unless it is your lift that is the culprit i will need pics to verify, well till then, good luck on the yoke, axles, and driveshaft yokes dont like to do burnouts with oversized tires, it is asking for breakage
Old 04-01-2005, 12:44 PM
here is a pic of my front that you can use as a refrense were does it rub?
Old 04-01-2005, 01:32 PM
yeah your lift spindle is a lot more curved than mine.
Old 04-01-2005, 02:39 PM
sk8inrj1's Avatar
Well heres the most recent pic. After this pic I have painted the front and rear bumpers white(only the metal part), removed the license plate to move it about my rear view mirror in the windshield, and got rid of that yellowed FORD emblem and just stripped it to chrome.
Old 04-01-2005, 03:15 PM
blackflareside, well it looks like you are as wide as you can go with your current lift, unless you find some used fabtech steering knuckles(they are called steering knuckles not spindles on the 4x4) good luck
Old 04-01-2005, 11:56 PM
Well hopefully this works!!
Old 02-13-2007, 10:56 PM
95'F-150's Avatar
What tires and rims are those?
Old 02-14-2007, 02:06 AM
sean_somer's Avatar
also what headlamps & corners
wish i could get a camera to take pictures of mine
Old 02-14-2007, 02:43 AM
1BDf-150's Avatar
Old 02-14-2007, 03:50 AM
Memo21687's Avatar
Old 02-14-2007, 09:24 AM
ChrisT's Avatar
Quick Reply: all lifted 97-03 show us a pic
