Wheel Hop on F350 --->
Old 01-20-2001, 05:17 PM
RI995.4L's Avatar
Post Wheel Hop on F350 --->
Any Idea on how to stop this on a 1Ton ???
Thanks,
Jon
1999 F350 SD XLT 5.4L Black!
See my TRUCK!!
Old 01-20-2001, 07:04 PM
BigGreenFord's Avatar
Smile
I have a 97' F-250HD and it does the same thing. The only answer I have recieved on this question is you need to buy a very stout set of ladder bars. Another solution would be to quit spinning.
Mods: K&N FIPK
2" Skyjacker front
add-a-leaf
33"BFG Mud Terrain
Dual 3" exhaust
Old 01-20-2001, 07:49 PM
JerryH's Avatar
Post
Some of the lift company's make traction bars that mount over the front half of the leaf. It's really a problem with the 4 inch blocks on th 97 and earlier F350 4X4's.
Jerry.
Old 01-21-2001, 01:20 AM
Matt90GT's Avatar
Post
BigGreenFord hit it right on the head. You see them blocks between the leafs and the axle?
This is causing axle wrap. This is why you should never lift with blocks! (i know it is factory, but aftermarket lift). Cheap cheap cheap!
basically you can either get some traction bars like from Rancho that connect from the frame to the bottom of the axle or call up like National springs and have them make you a new set of springs to eliminate that block.
Old 01-21-2001, 09:50 AM
JerryH's Avatar
Post
The 97 and earlier F250 only have 2 inch rear blocks, F350 have near 4 inchers. I took my F250 CC Powerstroke 4x4 into Devils Kitchen in Utah. Had a 2.5 inch Tuff Country and I actually used Dodge 4 inch blocks in the back. I did get some hop on the ledges but it made it fine. Fun!!
Jerry
Old 01-21-2001, 10:18 AM
RI995.4L's Avatar
Post
Thanks Guys,
Anyone have REAL world exprience with the traction bars and maybe a pic (or site) that sells them ???
Thanks again,
Jon
See my TRUCK!!
Old 01-22-2001, 11:38 AM
Matt90GT's Avatar
Post
Here is the rancho ones that connect to the bottom of the axle:
http://www.gorancho.com/traction.htm
The only bad thing about these is they hang down, but so does the driveshaft, so....
I had some traction bars on my 4.0L ranger after I hopped up the motor. They mounted on top of the leaf spring then forward to the frame. It made a huge difference in traction! But the ranger only had like a 1 3/4" factory block in the back.
Old 01-22-2001, 05:45 PM
RI995.4L's Avatar
Post
Thanks MAt,
I made something similar to that for my '83 Toyata 4x4. It connected from the Frame Crossmember to the Center housing of the rearend. I used 2 Hiem joints and some pipe....Worked Great.
I wonder
Mat,are you on the Corral? My name on there is RI85GT!
See my TRUCK!!
Old 01-24-2001, 07:56 PM
GIJoeCam's Avatar
Post
Do a search here:
www.ford-diesel.com
Guaranteed to find your answer there.
-Joe-
98 Explorer (Lemon Law Case in Progress)
'00 F-150, X-cab, 4x4, Lariat, Off-road, Trailer Tow, Holandia Sunroof, built 11/99 picked up 10/00!Clear Corners, Manik Stainless Steel 1-piece brush guard, Custom CB wiring, Uniden PC76-XLW CB radio with K-40 Magna-Mount antenna (for now), 1 set of 165 watt KC Daylighters (for now... more on the way) Custom switch mounting plate and overhead console.
List of planned mods: Clear tails, color matched trailer hitch with stainless steel ball, torsion bar tweak, bug deflector, spray in liner, and a tonneau of some sort...
93 Probe GT teal, OE rims painted to match, bone stock drivetrain.
Old 01-24-2001, 09:12 PM
BigRed2's Avatar
Post
Check these out !
http://www.activesuspension.com/
99' F-150 XLT 4.6L SC 4X4 ORP LS
- Ariad FIPK
- Superchip
- ASP Underdrive Pulleys
- Accel Coil Packs
- FMS 9MM Plug Wires
- Rapidflow 3" single
CatBack exhaust
- Fluidyne Trany cooler
- A.R.E. Hard Tonue
Cover
- Duraliner bed liner
- "W" Bucky Badger
Hitch Cover
- Mobil1 5W-30
- Outerwears
pre-filter cover
(Blue of course).
Old 01-24-2001, 10:07 PM
RI995.4L's Avatar
Post
Wow
Those are pretty cool. Anyone ever try them???
Thanks guys
Old 01-24-2001, 10:10 PM
Matt90GT's Avatar
Post
<font face="Verdana, Arial" size="2">Originally posted by RI995.4L:
</font>
Yup. same name. :-)
Quick Reply: Wheel Hop on F350 --->
