Go Back   F150online Forums > Powertrain & Mechanical > Suspension
Sign in using an external account
Register Forgot Password?
Register Photos Vin Decoder FAQ Members Search Today's Posts Mark Forums Read VendorsGarage
Suspension SPONSORED BY:
Thread Tools Search this Thread Display Modes
Old 01-09-2001, 09:36 PM
Garage is empty, add now
Vehicle: 1997 Ford F-150
Question front sway bar
Is there any way, to preload the front sway bar, so it holds the front wheels tighter?
97 std. long bed
cat back
soon to have 4 in.drop w/4link @ panhard rod
Pretty plain mono-chrome white
all I want for Christmas is a
red/white/blue paint job and a roll bar.
Old 01-09-2001, 11:41 PM
Post
Not sure what you are trying to accomplish, but urethane bushings from Energy Suspension are much stiffer than stock. All the bar end and middle bushings are about $30 and install in about 1/2 hour. You will probably have to special order them from an auto parts store.
Old 01-10-2001, 07:47 PM
Question
The bar does not preload. It rotates freely on the center bushings and the end-links are bolted down to the lower suspension freely to what ever position that it moves to. Hellwig recently released the new front bar for 97-2001 2WD trucks and it makes a huge difference on flat cornering and handling flex.
2000 F-150 XL, RC, LB, 5.4L, 4R70W, 3.55LS,
Class III tow, Payload #3, & Convenience pkgs.,
4-wheel disc/ABS, Chestnut/Parchment 40/60,
Ford bedliner w/Paintsaver & gas/wheel/spare locks,
K&N F.I.P.K. w/Outwears pre-filter, Superchip,
Dynomax ultra-flow welded 3" cat-back w/ 3" Y-pipe,
Hellwig front & rear anti-sway bars, Rancho RS 9000s,
Mobil 1, K&N oil filter.
Old 01-11-2001, 08:16 AM
Vehicle: 1998 Ford F150
Post
Got my Daystar front anti-sway bar polyurethane bushing from Performance for around $30.00. They work great and I am happy with them but if you want more then get the new Hellwig bar, is thicker than the OEM.
My Ride: 1998 F150 4x4 Lariat Supercab Flareside 5.4L in Oxford White/gold, ORP, Tow Package, 3.55 Gears.
Modifications:
K&N FIPK
Gibson Supertruck Exhaust System
Stepshield door sill protectors
Performance Accesories 3" Body Lift
Superlift 3" lift blocks
Performance Lift Lips
Gabriel Gas Ryder LT VST Shocks
Daystar Front Anti-sway Bar Polyurethane Bushings
Heckethorn Steering Stabilizer
35x12.5R16.5LT BFG All Terrain KO's
16.5x9.75 American Eagle 589's.
Photos at: http://www.communicomgroup.com/jmtruck
Old 01-11-2001, 08:18 AM
Post
Troy 67
I wonder if what you are looking for is preloading the torsion bars.
Old 01-12-2001, 07:59 PM
Post
Doesn't the sway bar have torsional load on it when you corner? I'm going to try new rubber on it first, but I don't think they will do what I want. I want to corner flat.
By the way the thing about the torsion bars, on the old "Chivy Luv" trucks you could use the torsion bars to lower the truck. Know of any one who has tried this with success?
Old 01-13-2001, 07:03 PM
Cool
troy67- Polyurethane bushing are firmer and can help, nothing like the larger front Hellwig bar that I installed (big difference in cornering, best suspension mod by far that I did). The operation of the bar is similar to wringing out a washcloth. It's not working while it sits still on a flat surface.
Old 01-14-2001, 08:57 AM
Post
There is torsion at some points but no adjustment. The poly bushings will help but the new Hellwig is better.
You can adjust ride height in the front adjusting the torsions but you will be changing the bars preload and ride comfort depending on the adjustment. Too much to get it taller will put front components like the CV joints in stress. Too much wear an tear. And you may need alignment. You will be limiting down travel as well.
If you go down, then it's almost the opposite.
Modifications:
K&N FIPK
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are Off
Pingbacks are On
Refbacks are Off
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company
Emails & Contact Details
Search Engine Friendly URLs by vBSEO 3.5.2
