the Hellwig front bar is finally available
Just FYI, that after 4 months of waiting, it finally showed up. #7646 1997-2000 front 2WD. The OEM is 1&1/8", the Hellwig is 1&7/16". It's huge and heavy. It handles much better and makes alot more difference than the rear one did. It's new and had the wrong end link bolt and spacer size. New ones are on the way, old ones work fine. I gave them the heads up on the problem and size needed.
2000 F-150 XL, RC, LB, 5.4L, 4R70W, 3.55LS,
Class III tow, Payload #3, & Convenience pkgs.,
4-wheel disc/ABS, Chestnut/Parchment 40/60,
Ford bedliner w/Paintsaver & gas/wheel/spare locks,
Mobil 1, 3" cold air box modification, Superchip,
Dynomax ultra-flow welded 3" cat-back w/ 3" Y-pipe,
Hellwig front & rear anti-sway bars, Rancho RS 9000s.
Location: Houston, by way of every major city in America.
on
What is the deal with that,anyway? I have tried to order an end link kit,twice,and both times it came with the wrong size.
Length,and bolt size. Can't these guys figure it out yet? Sheez! lol.....98
98 F-150 4.6 Litre XLT2wd Ext. cab
prarie tan/tan int.
K/N gen.II fipk
custom dual exh/gibson rectangle tips/rear exiting.
color matched snuglid
Superchip!!!
Westin nerfs blk .powdercoat
Clear front corners
Clear Euro tails(Altezza style)
Cobra 75WXST cb w/weather alert
Kenwood cd w/Radio Shack speakers,don't laugh it sounds pretty good
Viper 500HF Security system
On the way/wheels,tires,air dam, etc..etc.......
doin the monochromatic boogie
on the front end.Billet grilles on order
www.my-f150.com still want to lift it,YES!
Fender Guitars,ROCK!!!
http://www.bigsandy.net
officialtomwaits.com
reverendhortonheat.com
prarie tan/tan int.
K/N gen.II fipk
Superchip!!!
Clear front corners
HI!... MAX MITCHELL : COOL! I've always thought that the stock sway bar on these trucks was really small for it's size. How much did it cost? Does it come with new polyurethane bushings? Does the end links come with new polyurethane bushings? How does the handleing of your truck compare now to before? THANKS "NEAL THE H.P FREAK"
NEAL " THE H.P FREAK"
'99' F-150 XLT SPORT, oxford white, reg cab shortbox stepside,5.4, auto, 4.10L.S, captain's chairs, bedliner, GTS carbon fiber headlight covers, ***** CEPECK clear halogen driving lights, GTS slotted tailight covers (painted oxford white), fiberglass smooth wiper cowl (painted OXFORD WHITE), FORD locking lug nuts, tinted windows,true duel exhaust with 2.5 inch mandrel bent pipes and FLOWMASTER 3 chamber mufflers with 3' tailpipes exiting before the rear wheel like the LIGHTNING, HELLWIG rear stabalizer bar, 3 AUTOMETER guage pods, filled with tranny temp, engine temp, and oil preasure AUTOMETER "PHANTOM" guages,custom fabricated air intake trac and huge K/N filter, TPS mod, BELLTECH 2-inch rear drop, custom programed SUPERCHIP, BAUMANN ENGINEERING shift kit (on stage 5 setting)BYPASS CLUTCH CONTROL VALVE/PREASURE REGULATOR VALVE, ASP POWER PULLEYS, custom tig welded and ported JBA "JET BLACK coated headers, twin DERALE 16 INCH ELECTRIC FANS, PERMA COOL 14"/10" tranny cooler with 10" electric fan, custom ported (STOCK) throttle body, custom digital air intake temp sensor, custom ported TB intake elbow, relocated ATS.
FUTURE MODS : FORD SVT 24LB INJECTORS, CUSTOM SUPERCHIP FLIP-CHIP, BBK 75MM THROTTLE BODY, 80MM PRO-M MASS AIR METER, AADI F1 RAM AIR HOOD WITH CUSTOM FABRICATED RAM AIR SET-UP, CAL-TRAC TRACTION BARS, EXTRUDE HONED INTAKE MANIFOLD, SHM CUSTOM FUEL RAILS, SHM "RACE WATER PUMP, 90/10 FRONT CE SHOCKS, 70/30 REAR CE SHOCKS, BELL TECH 2/4 DROP, EXPEDITION CENTER CONSOLE, HARLEY DAVISON F-150, LOWER FRONT VALANCE (painted oxford white) and a KENNE BELL BLOWZILLA SUPERCHARGER.
ESTIMATED H.P TO DATE : 345H.P / 425ft/lbs of torque.
CURRENT PERFORMANCE : 1/4 MILE - 14.53E.T * MPH - 93.00 * 0-60MPH - 5.8 * 1/8 MILE - 9.2 * 60 FT - 2.0
OTHER TOYS : "83" PRO STREET FORD RANGER : 351-w stroked to 408c.i 625H.P (natural), 875H.P with 250H.P "BIG SHOT" N.O.S kit, tubbed (crome moly tubing), 12 point chrome moly roll cage, 4-link with coil overs, MUSTANG II front suspension, c-4 tranny (race prepped), 4000rpm stall converter(8 INCH), 3" chrome moly driveshaft,AUTOMETER guages, 15.50 MICKEY THOMPSON rear tires, 4" M/T front tires, CENTERLINE CON-VO PRO rims, fiberglass hood - bumper - prostock hood scoop, wishbone trac-link, two chrome moly driveshaft loops, 16 gallon RCI fuel cell,etc
I paid $119.95 + shipping from J.C.Whitney. Yes, it has black polyurethane bushings for the the bar and end links. The handling is great for a big truck; much improved. The front did more than the rear. It has less front body roll around corners, and is really nice at high speeds (like a curved exit ramp). Nothing about it is harsh. It's nice but still isn't a sports car..lol.
HI!... MAX : Thanks for the reply. I already have HELLWG'S rear sway bar. I'm very pleased with it. No problems for the last year and a half. As soon as I pay MIKE T for my new FLIPCHIP SUPERCHIP, it will be 24lb injectors and then HELLWIG's front sway bar. Thanks for letting us all know that it's finally out on the market.
Max- Was front sway bar install difficult? Looks like a tight fit getting bar ends through there. Also, do you have four wheel disc brakes on your truck, and if so, where did you get em, how much, etc.
BTW, I just put some Bilsteins on the front of my truck, they're real nice, much better than the Rancho 9000s I had. Worth the price (about $63 ea @ Autozone stores, must order).
Welcome seeker333 !!- The front bar is extremely easy to install. It is a direct bolt on and much easier than the rear. The bar ends are simple. You take off the end links, drop the center U-brackets, and it drops right down and out; install in reverse order. Yes, my truck has 4 wheel disc and ABS standard from the factory. Yes, Bilsteins are nice, I had them on an import car. I got the Ranchos to be able to adjust them myself, especially for the rear and towing.
