What would you do?
What would you do?
Ok, I'm having a new frame put on my truck, old one got bent in an accident (long story).
Anyway, they're going to lift the truck off the frame to put the new one on. The body shop guy said he could easily install a body lift, whatever I wanted, but he doesn't do suspension lifts -- never done them.
With money not being a factor, what would you do, go elsewhere after the new frame for the suspension lift, do the suspension yourself (I don't have much of a tool collection), get a body lift AND the suspension lift?
I'd really like the suspension, as I'd like to still be able to haul stuff around like a boat. I've read all the previous posts, it seems that a suspension lift with the add-a-lead in the rear is the best in the long run for the truck. I'm looking at the Rancho or the Superlift (in the 3-4" range).
Thoughts, suggestions? Any help is needed.
97F150 XLT SC 4x4 Flairside 4.6 V8 5sp Dk Toreador Red, 3.55LS
ARE tonneau cover, p255/70rx16 tires (came w/235), Superchip
Pioneer CD w/4 Polk Speakers, skid plates
bed liner, side window deflectors, reese hitch, K&N air filter
40s-2chamber Flowmaster, Bosch +4 spark plugs, rustproofing
Better Built Stainless nerf bars
heavy duty shocks
heavy duty shocks
Well as long as they're gonna have the body off the frame I'd have them do a body lift. You could always add the suspension lift later. If you didn't have them do the body lift and then later you decided you wanted one it takes like 12 hours to install.
Get the Body lift now then suspension later.
I have the Performance products 3" lift kit. I does interfere with the brush guard but you can make it work. I did. The bumpers come with a relocation bracket, but the instructions do say that you can no longer tow with the bumper so you'll need a hitch.
98 F150 2WD,Bright Red, Regular Cab, 4.2, 3.55, 5 Speed, Superchip, 2 Superchip Decals (I Think They Add 5 HP Each), 3 Inch Bullseye Lift Spindles, 3" Body Lift, 1" Coil Spacers, 3" Blocks In Rear,Manik Grill Guard, Lighted Logo In The Tailgate,Nerf Bars, Vent Visors,Air Box Mod, Fog Lights Mounted In Front Air Dam ,6 Kc DayLighters, Back Up Lights, Dual Batteries (One's an Optima Yellow Topper), Alpine CD Player, 2 Kenwood Amps,Polk Audio DX7 5X7's In The Front Doors, 10 Inch MTX Blue Thunder SubWoofer, Tinted Windows. 35" BFGOODRICH ALL TERRAIN KO'S Mounted on 16.5x9.75 American Racing Baja Rims
<A HREF="http://www.zing.com/picture/pf95408d4c385a927598e7884a5151a2a/ffd9add3.jpg" TARGET=_blank> </A> <A HREF="http://www.zing.com/picture/p7e554b755e2bb9aa66f774b76d669a34/ffd9add2.jpg" TARGET=_blank> </A> <A HREF="http://www.zing.com/picture/pe0557f5ae565a8da25e9ce11b08009df/ffd9add1.jpg" TARGET=_blank> </A> <A HREF="http://www.zing.com/picture/p810cf5ac82eb57b84a62f699fb0f38e7/ffd9ad72.jpg" TARGET=_blank> </A> <A HREF="http://www.zing.com/picture/p3d23039451896f609154656f22698b8f/ffd991ca.jpg" TARGET=_blank> </A>
CLICK THE PIC FOR A BIGGER ONE
..........."IF YOU CAN'T STOP, SMILE AS YOU GO UNDER"...........
'00 Toyota Celica GT( Wife's Car )<A HREF="http://www.zing.com/picture/p5ef23f8639c03b4f05f21e4f35c15cfb/ffd9ad71.jpg" TARGET=_blank> </A>
Pics @ http://www.angelfire.com/la2/ccla/
[This message has been edited by ccla (edited 08-28-2000).]
If money was no option I would do it up completely, but for now I'd just get a body lift. Because if you go all the way you will need new tires and probably rims as well just to make it look right. You could get away with the current tires with just the body lift. Also with the bigger tires you would probably need to change out your gears in the axles, to compensate for the different sizes.
GOLD RUSH
'99 F150 XLT SC SB 4x2 Harvest Gold
Factory[*]5.4[*]3.55 limited slip[*]Trailer towing package[*]In-dash CD player
Aftermarket[*]Ford Beanie bear[*]Slip on extender mirrors[*]Powerstop brake controller[*]Covermaster C1000 topper with wing[*]BugflectorII[*]Ventvisors (front&rear)[*]3 www.f150online.com decals[*]Ford Lumi Logo[*]Steelhorse Billet grill[*]Ford hitch cover[*]Yellow wire loom[*]Hyper White head light bulb[*]Painted to match AVS slotted taillight covers[*]Ford system 4 alarm[*]Clear turn signals[*]"Blazer" strip reflectors under tailgate[*]FORD script antenna painted to match[*]Next who knows???
<A HREF="http://www.firezap.url4life.com" TARGET=_blank> </A>
<A HREF="http://njf150truckclub.homestead.com" TARGET=_blank> </A>
firezap@f150fanatic.com
firezapper@home.com
[This message has been edited by Firezap (edited 08-29-2000).]
GOLD RUSH
firezapper@home.com
