3" spindle lift installation
Going to do this installation this Saturday. Is there any tricks of the trade that I should know, or that someone has experience?
Trying to find out how hard this installation
will be or if I'll need special tools to make it easier?
Thoughts or comments??
Doug
Doug
An Impact Wrench will make your life a lot easier. Other than that, Normal tools.
98 F150 2WD,Bright Red, Regular Cab, 4.2, 3.55, 5 Speed, Superchip, 2 Superchip Decals (I Think They Add 5 HP Each), 3 Inch Bullseye Lift Spindles, 3" Body Lift, 1" Coil Spacers, 3" Blocks In Rear,Manik Grill Guard,Nerf Bars, Vent Visors,Air Box Mod, Fog Lights Mounted In Front Air Dam ,4 Kc DayLighters, Back Up Lights, Alpine CD Player, 2 Kenwood Amps, 10 Inch MTX Blue Thunder SubWoofer, Tinted Windows. 35" BFGOODRICH ALL TERRAIN KO'S Mounted on 16.5x9.75 American Racing Baja Rims
..........."IF YOU CAN'T STOP, SMILE AS YOU GO UNDER"...........
'00 Toyota Celica GT( Wife's Car )
Pics @ http://www.angelfire.com/la2/ccla/
[This message has been edited by ccla (edited 03-07-2000).]
Domo,
make sure that you start with the driver's side. You will have to file the ABS sensor in order for it to fit.Have a torque wrench ,bearing grease and a puller handy. It took me about 4 hrs to do it by myself. Try to get a friend to help you out and you will be done in about 2 hrs.Good luck. If you have any questions e-mail me. veloci@gateway.net
Black 99 xlt sc flairside,4.6 2w.d.,50 series flowmaster catback,
superchip,
rsx shocks,
hellwig sway bar,
3" lift procomp spindles,A/R PHYTHON,285/75/16 A/T B.F,2' BLOCKS REAR.
FUTURE MODS: driving lights, LS AND 4.10 GEARS.
superchip,
rsx shocks,
hellwig sway bar,
The truck looks good, and very happy with the result. In short the installation went fine, but had a problem with the toe alignment. It was way out of wack. Luckily my brother knew how to make the necessary adjustments and was able to make the truck driveable. I'm sure the alignment is still a little out, but I'm waiting until I get new rims and tires this Wednesday before taking it to a alignment shop. That way it's all done at once..
