SuperCrew
Engine Problems HELP!!!
Old Oct 29, 2001 | 08:40 AM
FordBoy's Avatar
Exclamation Engine Problems HELP!!!
I just installed an Air Raid intake system in my 01 Superscrew and my engine is having problems. I have a service engine light, i have no power, and I have major problems trying to start it. How do I check the engine light and what is wrong???
Old Oct 29, 2001 | 12:06 PM
dcovell's Avatar
Maybe the mass air flow sensor got screwed up. You may need to bring it into the dealer to have them look at it.
You may also want a friend or a local mechanic (one you trust of cource) to look at it as the dealer will most likley NOT, cover this under warrenty as you made non-factory change and the dealer is gona cost a lot more.
You may want to take it out and try it again???
Good luck
Old Oct 29, 2001 | 04:30 PM
jonjulkevkat's Avatar
Pu it back to stock, if you can't figure it out, and see if you still have the proble. If yes, then it's should go to the dealer. If problem goes away, then go back through the installation step by step, it's fairly simple. I have on by "airforceone" it's basically the same, and I've noticed power gains.
Old Oct 29, 2001 | 04:41 PM
FordBoy's Avatar
I fixed the problem by taking out all the connectors and putting them back in but I still have that light. How do I reset that?
Old Oct 29, 2001 | 08:37 PM
Former Sponsor
Hi Fordboy,
If you mean the check engien light, , disconnect your battery for a few minutes, then reconnect it, and start it up. If the check engine light was just from a temporary condition, it won't come back on. If it does come back on after disconnecting the battery for a few minutes, then you'll need to have the ECU scanned for error codes to see why it's throwing that light, what is causing it.
Good luck!
