can someone post what the part numbers are for the 2001 lightning headlamps and markers? also the part no. to the tail lights too? does anybody know if you need to change the header panel for this or does the lights match to the existing header? thanks curt
Mrtailight.com is a good web site if you know what you want.
I am in the search as well for what looks best and exactly what to order. I have written to Mt Tail-light to inquire about this and and after a week I still have not heard a response.
Somebody did tell me how to change the tail-lights (it is the 2 screws you see when the tailgate is lowered)
NO mention as to how to change the front light or corners. Any tips or pics... would be good.
also any opinions as to whether the clears "alone" with the tails in the way to go -------- or is is better to go all "lightning"
this is a great forum with very helpful guys (and girls) but this topic has been a tough one to solicit advice & help on.
Oxford white/silver 2-tone
5.4 liter
Superchip Flip Chip
Airaid Induction System
custom true dual exhaust w/ Dynomax Mufflers
3.55 Limited Slip rear end
Cervinis Ram Air Hood
Sylvania Silver Star headlight bulbs
Lightning Tails
Class III towing package
Westin Nerf Bars (Chrome)
Pendaliner
US Weld tool box Stereo Upgrade
Head Unit : Alpine CDA 7977
Speakers : 4 Kicker 5x7 2002 hi power K57's
Amplifier: Alpine 5 channel mrvf357 V-12 mounted in passenger side rear pannel
Subwoofer: Kicker 8" VR Sub2 dvc in a custom built box under driver side passenger seat
In terms of which light combo to go with, it is just personal preference. I wanted to eliminate the amber entirely since my truck is white, so I went with the lightning tails and clear corners. Many like the new lightning headlights a lot so for those the accompanying lightning corners are the only way to go.
As for removing the corners, pop the hood and above each corner light is a screw. Remove it and the corner should slide forward.
regarding ur front blinker,corner, lights. did u buy those from Mr. Light along side of ur Lightning Tail Lights??? b/c they offer the "side lights" which i'm not too clear on. is the side lights the front corner blinker lights? or side lights as in behind the front wheel-well lights?
anyhow, i've been shopping for Lightning lights and Mr. Taillight.com is the cheapest so far for the rear tail lights. i have found front corner clear lights as low as $54.80. but not sure if those lights are similar to the $110 "Side Lights" on Mr. Tail Light.com
Mr. Taillight is COMPLETELY out of all Lightning Lights. I recieved an email from them this morning with no mention when or if they will be getting more. Other than Mr. Taillight, try OEMFORDPARTS.COM or FORDPARTSONLINE.COM. They are a little cheaper than a local dealer.
Here are the part #s and prices I received from Tersesa @ OEMFORDPARTS.COM
Tails
1L3Z-13405-CA
1L3Z-13404-CA
List - $161.67 EA
oemfordparts - $116.40
Headlights
1L3Z-13008-BB
1L3Z-13008-AC
List - $191.67 EA
oemfordparts - $138.00
Corners
1L3Z-13201-BA
1L3Z-13200-BA
List - $113.33
oemfordparts - $81.60
3rd Brake Light
1L3Z-13A613-AA
List $183.33
oemfordparts - $155.83
just a reminder to those of you who get a hold of the Lightning tails:
the stock screws that came with your SCrew are TOO long for the bottom hole of the lightning tails. you need to either chop the screw or use about seven 1/4" washers (i did the latter on my SECOND set of lights after the dealer replaced the first that got poked through on one side) to make sure you don't poke through the casing.
don't want it to happen to anyone else...
regards,
Wes
www.weslazara.com/screw Gen3 Lariat 4x4, 5.4L, Lim. Slip, Black Ext./Graphite Int., Tow Pckg., 60/40 bench, Moonroof, Bed Ext., Cab Steps, Rear Window
Ordered: 1/12/01
Picked up: 3/2/01
socalcrew I looked at that site also is there a date when mr taillight will get more in ? I get my wheels on 10/29 and then i want to get the L lights also.
