09-23-2001, 09:53 PM
Vehicle: 2001 Ford F150
Screw to Lightning Tail lights & clear Fronts
I would like to to go to Lightning tail lights and the clear front corner lights
3 QUESTIONS:
1. Where is the best place to order them ??
2. Is it much of a job to change them?
3. Approximate price??
thanks
any other info or suggestions would be appreciated
thanks
Mike
Oxford white/silver 2-tone
5.4 liter
Superchip Flip Chip
Airaid Induction System
custom true dual exhaust w/ Dynomax Mufflers
3.55 Limited Slip rear end
Cervinis Ram Air Hood
Sylvania Silver Star headlight bulbs
Lightning Tails
Class III towing package
Westin Nerf Bars (Chrome)
Pendaliner
US Weld tool box
Stereo Upgrade
Head Unit : Alpine CDA 7977
Speakers : 4 Kicker 5x7 2002 hi power K57's
Amplifier: Alpine 5 channel mrvf357 V-12 mounted in passenger side rear pannel
Subwoofer: Kicker 8" VR Sub2 dvc in a custom built box under driver side passenger seat
(2003 Harley Electra Glide Classic - hence fewer posts here)
09-23-2001, 10:50 PM
The best place I found was Mrtailight.com, he sells a complete set for front and rear and includes headlights and bulbs.
09-23-2001, 11:14 PM
Vehicle: 1999 Ford F 150
Hey guys, another thumbs uP for MrTailLight.com...... give Steve a call and I just bet mention Brandon from Kansas City and he will make you an offer you might not wanna jump over but rather all over it. Look up
WWW.MrTailLight.com and tell his I sent you.
ShowYa
www.MrTailLight.com
Just an old beat up pick up truck!
09-24-2001, 12:18 AM
i've got an extra set of lightning tails I'm selling. one side got poked through with a screw, the other side slightly bulging where the screw pushed up against it (not noticeable unless you stick your face up to it though). will part with them for $60 plus shipping.
regards,
Wes
wes@myf.org
www.weslazara.com/screw Gen3 Lariat 4x4, 5.4L, Lim. Slip, Black Ext./Graphite Int., Tow Pckg., 60/40 bench, Moonroof, Bed Ext., Cab Steps, Rear Window
Ordered: 1/12/01
Picked up: 3/2/01
MODS: Airforce 1 FIPK, Gibson Sweptside Exhaust, Bedrug, Husky liners, 2001 Lightning headlights, corners, taillights, 3rd lamp
09-25-2001, 11:07 PM
another ???
I wrote to Mr Tailight... have not heard back yet
do the clear corners look good witht the screw headlights??
are there any advantages to the lightning headlights?
to remove the taillights do you remove the screws that are visible when you lower the tailgate?
is it much of a job.... ???
thanks
Mike
5.4 liter
Superchip Flip Chip
Lightning Tails
Pendaliner
US Weld tool box
Stereo Upgrade
09-27-2001, 10:55 PM
I need help
It is getting embarassing to have to keep this post alive
BUT..........
I need help.... how about someone trying to answer a few of the above questions........
I was very amused about the harley badge thread.... and you guys are normally full of helpful advice.......... so come on...
thanks......
mike
5.4 liter
Superchip Flip Chip
Lightning Tails
Pendaliner
US Weld tool box
Stereo Upgrade
09-27-2001, 11:10 PM
Vehicle: 1997 Ford F150
Ok here.....the corners look good on just about anything, best w/ lightning headlights and/or projector type lights.
Advantages.....well the headlights are projector style, their better than the stock lights on the 150's, 250's (excluding 02's) and if you use higher watt bulbs, i.e. xenon, PIAA, their even better.
Yup the tails come out via the 2 screws that you see when you lower the gate, took me all of 6 minutes to put them in, but be very careful when you put the screw back in that you dont go too far(see above). (also throw in a couple extra washers on the screws when you put them back in, I used 2 for each)
All in all, the lights are worth the $$$, and the make your truck stand out.
http://www.f150world.com/mygallery.asp?id=1357
Display Modes
Linear Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
