Home Discussion Forums Photo Gallery Product Directory Technical Articles Recalls & TSB's Product Reviews Classifieds Photo Galleries Ford Truck News Event Calendar Advertise with us
F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Other F-Series Trucks > SuperCrew
Thread Tools Display Modes
Old 08-10-2001, 02:48 PM
Question Shifter position
Hope this doesn't sound to dumb.
I've always been under the impression that no matter what position the shifter is in, that you always start out in 1st gear. When I have my shifter in "2" it starts out in 2nd gear not 1st. Is this normal? When the shifter is in "D" or "1" it starts out in 1st gear. Maybe I better look in the manual.
Coop
Old 08-10-2001, 07:48 PM
Yes with the shifter in second gear it will start out in second gear. This has been very advantagous for my Pontiac GTP, coming off the line if you start in second gear it reduces wheel spin and actually gives a much quicker response then dealing with keeping the tires on the ground and going thru first.
2001 F150 SuperCREW 4x4 Lariat Gen.1,
Delivered with - 5.4L, 3.55LS, Oxford White with Harvest Gold accent two tone, skid plates, sliding rear window, class III towing group, box extender, leather captains chairs, 6 disc changer, tint all around, chrome nerf bars, bug shield, ford alarm system with keyless entry.
Add ons - Toffskin sprayon liner, black RAM grill guard, Oxford white taillight covers, black Manik taillight tube guards, chrome side rails, BORLA exhaust, K&N FIPK Gen II, PIAA 520 Ion drivers, Superchip flip chip, Polk Audio 6 1/2"Components in front and POlk EX series 5x7's in back with Sony Xplode 800wx4 amp, Procomp AT 33x12.5x17's
Old 08-11-2001, 02:31 AM
HUh?
The only advatage I can think of, maybe, is if its real slick...like ice. Is that what you meant?
2001 SCrew Lariat Gen II, 5.4L, 4x4, Solid Arizona Beige, Leather 60/40, Slider, LSD, Tow Pkg., Cab Steps, Skids
Mods: Lund, Clear bra, SnugLid
Future Mods: Superchip
Oil: Amsoil
Old 08-11-2001, 10:38 AM
Cooper, my GTP is supercharged and in first gear will flatout light the tires up on any surface. By starting in second gear less immediate torque is put on the wheels, reducing the initial wheel spin. It does produce better 0-60 times starting in second in that car. I am not saying that starting in second will produce better times in all vehicles, not at all. I was pointing out the fact that not only Ford but all transmissions will start in second gear if that gear is selected and that in the case of my Grand Prix GTP it is a benefit to do so. I picked up this little trick in a Car and Driver rag that was doing test on the GTP when it first came out. They had noted the significant improvement in times when starting in second gear. I hope this helps explain my answer.
Old 08-13-2001, 05:10 AM
Yes to reduce wheel spin because of the surface conditions(mud sand) you can start in 2nd to reduce wheel spin..
OEM Turbo, OEM Injectors, OEM Transmission, Low 14's at 98mph, Four Position Chip, Fuel System mods, Hx line, In-tank Mods, Fuel Regulator Mods, Quad Pod-Autometers/3 guage cubby-hole/7 guage total
2000 F250 PSD Auto Xcab LS 22.67mpg (best)over 21avg, Propane (right on), 3.5 DP Exhaust SS, AFE Coolair Induction, Transgo shift kit, 6 Gallons Amsoil, Mag Hytec deep pan, 80K, 2200watt Bi-Amp stereo, Rancho 9000, 255/85-16-Have my own shop-looking for 13's...5 different exhaust systems, 3 different chips...getting traction bars and suspension upgrades..
Performance--388+hp 818ftlbs, conservative, 9.1 sec 1/8 75mph, melting the tires, low 14's
2004 CC SB AUTO 6L
1969 Mach1 351C 4spd 3.50 LS Autocrosser, Negative Roll Kit, Sectioned lower arms, Centerlines 15X10 w/50's, Tri-brace, Monte Carlo bar, Rear Stabilizer Bar, Lowered(can you say on the ground), MSD Electronic Dist., Aluminum Intake, Holley 600
Old 08-13-2001, 01:03 PM
Thanks Guys.
It's finally sinking in now. Now that I know about it, i'll be using it alot when its slick.
Coop
Oil: Amsoil
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
F150Online.com and InternetBrands, Inc. are not affiliated with the Ford Motor Company
