Home Discussion Forums Photo Gallery Vendor Directory Technical Articles Recalls & TSB's Product Reviews Classifieds Ford & Industry News Vin Decoder Advertise with us
Go Back   F150online Forums > F-Series Trucks > SuperCrew
Sign in using an external account
Register Forgot Password?
SuperCrew
Look for a USED Ford F150
Carsdirect.com
Thread Tools Search this Thread Display Modes
Old 01-22-2012, 07:09 PM
2001 Ford Expedition
New screw. New problem.
Just bought and 02 supercrew lariat. Got a heck of a deal on it. Already have problem though. When it's in neutral the rpm's jump and will eventually even out and idle fine. Same problem occasionally happens in park. Drives and shifts fine. Any suggestions or has anybody else had the same problem
Old 01-22-2012, 08:28 PM
Garage is empty, add now
Vehicle: 2003 ford f150
Any codes? Milage? Motor? Mods?
You could clean the MAF, Throttle body, and IAC. Also check it over for vac leaks. These are all just guesses.
Love my box stock V-6
Old 01-23-2012, 01:07 AM
No codes. Completely stock. 103k. And its the 5.4L. I've read about the MAF so that will probably be the first the i clean.
Old 01-23-2012, 10:18 AM
Vehicle: 2005 Ford F150
Quote:
Clean the throttle body as well. See the How To's on tips to clean both if needed, but I bet either or both could be your issue.
Good luck!
Old 01-23-2012, 01:23 PM
In addition, IAC or TPS
Member: Never trust a person over 40 who drives a Chevy club
Flatheads ain't so bad!
Certified backyard mechanic I & II
Old 02-03-2012, 10:20 PM
Welp. Thanks for the help was able to fix idle problem. Now i have another issue. Got in my vehicle today and the service engine light, oil light, outside temp light, odometer, and direction reader was on. My truck would turn fine but wouldnt start. Unhooked battery to reset it. Then the truck started fine. Drove home 10 miles. Parked it, turned it off, pulled the key out, and the heater was still running full blast and a few of the lights stayed on. Any suggestions?
Old 02-04-2012, 08:51 AM
Vehicle: 2002 FX4 Screw
Does the truck have a moon roof/sliding sun roof? If so I have heard the seals can wear out and the drain lines get clogged causing water to end up in the dash.
Current ride...
2002 FX4 Screw with a flex a lite Efan installed
L swap supercharger work in progress...
Still gathering all the parts I need for the swap
Old 02-29-2012, 04:26 PM
2001 Ford F-150
Water Leak-Clogged Drain Moon Roof????
Yes. I am sure that is what the problem is. The mooon opens in the two airing out positions, but goes crooked once you try for full opening. There is an automotive center here in Atlanta that supposedly works on these that was recommended by the used truck dealer I bought the truck from.,
Old 04-07-2012, 09:26 PM
Vehicle: 2008 Ford f150
BeechKid is right just for giggles, what was the issue with the RPM flare ups? Man i would say a relay is messin up
Old 04-08-2012, 11:03 PM
I ran a bottle of seafoam through it and seemed to clean it up.
I dont have a moonroof.
I took off them gem and cleaned it up. Looked like it had some corrosion on it. The windshield has been replaced before, so im hoping that will fix it.
Old 04-14-2012, 11:34 PM
Vehicle: 2002 Ford F-150
Don't use seafoam anymore use chevron techron it will get alot cleaner and the other guys won't be too hard on you about it.
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
F150online - Archive - Top
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.2
Emails & Contact Details
