Home Discussion Forums Photo Gallery Product Directory Technical Articles Recalls & TSB's Product Reviews Classifieds Photo Galleries Ford Truck News Event Calendar Advertise with us
F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Other F-Series Trucks > SuperCrew
Thread Tools Display Modes
Old 08-01-2008, 11:09 PM
Gas Mileage is worse in the SCREW
I 've got a 2008 screw that I traded in my 05 scab for and the first thing I've noticed is I'm getting about 5mpg less than I did in the old truck. Does the flex fuel engine get worse mileage. I've also noticed the truck doesn't seem to have the same get up and go as the last. Surely it can't weigh that much more. Its got 20inch tires as opposed to the 18's on the last as well.
Anyone?
Sponsored Links
Old 08-05-2008, 10:38 AM
ermm .... tires are larger causing more weight for one as well as a larger cab with added weight there.
The engine howver is larger im guessing causing your decreased gas milage.
Wat engine did u have in the old one? 4.6 5.4 9.6 =)
Old 08-05-2008, 10:47 AM
Vehicle: 2005 FORD F150
Are you using the flex fuel? It is designed to run with flex fuel which does not have the same amount of energy that normal fuel does. So flex fuel already gets worse mileage to begin with, and then the added weight of a supercrew brings you right around that ball park. The reason flex fuel is "saves money" is because the government subsidizes it thus making it cheaper at the pump.
Click Sig to See Videos
2005 F-150 5.4L 3V Supercrew Lariat 4x4
Old 08-05-2008, 01:41 PM
APT APT is offline
Vehicle: 2003 Ford F-150
300 pounds extra for the same trim/equipment in a Screw.
Heavier wheels.
If you think it has less power, you are probably using more accelerator pedal which uses more fuel.
If you are actually putting in E85 fuel, expect 33% lower FE.
Same engine/trans/gears?
Old 08-16-2008, 02:24 PM
Vehicle: 2006 Ford F150
E85
When I ran E85 in my 2006 Lariat Screw, 20 inch stock Pirellis, my mileage dropped to around 11 in the city, down from 14.5 running regular fuel. I quit using E85 because it costs more to fuel with E85 than it does with regular!
Old 08-16-2008, 03:25 PM
Vehicle: 2007 Ford F-150
The government actually thinks they know what's good for us. The only winners are the farmers making a bundle off of us.
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
F150Online.com and InternetBrands, Inc. are not affiliated with the Ford Motor Company
