SuperCrew
How much gravel should I haul (safely)?
Old 10-20-2006, 08:32 PM
ReelWork's Avatar
It's a truck... Some of you guys act like these are those volkswagon trucks from the 80's..
When I built my shed I had 25 bags of 50 lb concrete, forms, 25 2x6x10's and 8 sheets of 3/4 inch P/T plywood.. Needless to say I was loaded to the hilt!
Do the math and I was probably around 1700 pounds in the bed.. Probably a little overloaded, but it did fine. If I did it again, I would probably stop with the cement at 1250 lbs..
Remember if you have 4-5 passengers, chances are you're closing in on 750-800 lbs alone.. Cargo is no different, weight is weight.
One suggestion though, keep the heaviest weight near the front of the bed and over the axles as possible..
Old 10-26-2006, 01:47 PM
vmac's Avatar
I just hauled 1 ton of Pellets (for a pellet stove) in my '02 screw 4x4. I drove apprx 30 miles on the interstate going 60mph. I had very little sag in the back, and the reason I only drove 60mph was the fast that I felt I could drive, and still stop. I had the load centered over the axle.
Just like others have said it is a truck. Do what you feel is safe.
Old 10-27-2006, 10:03 PM
imacreative's Avatar
I just completed a major landscaping project that included gravel as well as crushed granite. for my f150 supercrew 4x4, the quarry told me to just place a half yard at a time
Old 11-05-2006, 04:57 AM
uwood's Avatar
Well I guess I am the crazy one then. I have had 2.5 tons of CA6 in the back of my truck. Sagged a littl ebit but wasnt a problem. Then again I have also towed a little over 10,000lbs. (CAT skid steer and trailer) I have had no problems at all. Its a truck.....thats the way I look at it. If it breaks I fix it with better parts. That gives me an excuse to get it past the wife!
Quick Reply: How much gravel should I haul (safely)?
