What the biggest tire - F150online Forums
SuperCrew
Old 03-25-2006, 10:37 AM
Question What the biggest tire
I am in the process at looking at tires. I do not want to lift the truck or tightnen the torsion bars as of yet. So in saying that. I have two questions. What is the biggesst size tires that u can put on the stock 17 inch rims with out rubbing at any angle? And also what would be the widest rimsize and tallest tire that i can put on my stock f150 with out rubbing at any angle.
Old 03-25-2006, 11:18 AM
I would suggest going with a 285/70-17 (33x11.50) tire. You could mount them on the OEM 17x7.5 inch wheels or an aftermarket 17x8 without any rubbing or trimming. You could go with a 9 inch wide wheel, but you may or may not have to trim the front bumper's lower plastic valance. If you go to a 17x10, you will have to trim the valance.
Old 03-25-2006, 01:27 PM
Ive got 285/70/16 Coopers on mine with Eagle wheels also..... Had to do a little triming to the lower fascia, but nothing major.... The rims are 16x10....
Old 03-25-2006, 05:13 PM
That's the difference. When I had my 285/75-16's on the OEM 16x7 wheels, they were not even close to rubbing. When I mounting them on 16x10 wheels, they touched the front bumper's lower plastic valance.
Old 03-27-2006, 10:32 AM
Question Adding to my post
I also was wondering if i only went like one or two sizes bigger would i be fine keeping that stock spare tire? Or that is not even safe for a sometimes use on trucks?
Old 03-28-2006, 01:48 AM
After researching this often asked question, I believe it's 285/70/17 using factory 17" wheels. I got myself new set of BF Goodrich T/A KO in this size last week, and it looks sweet! Any bigger tires will hurt some in gas mileage and lose some power in acceleration without upgrading the gears.
Old 03-28-2007, 01:20 PM
I was wondering this also. Anyone have an idea?
Old 03-29-2007, 10:35 AM
It's a good idea to get a new spare that's the same size as the rest of your tires. Sometimes you can find cheap used tires at tire shops. But IF you don't, and you get a flat, put the smaller tire on the front. DO NOT put two different size tires on the rear axle, it will destory your limited slip parts.
Edit: If you like all terrrain tires, Nitto makes the Terra Grappler AT in a 295 width, and they typically cost less than the BGF ATs. 295/70/R17 = 33.26" tall tire. A TRUE 33" tire.
Related Topics
Thread
Forum
Replies
Last Post
Necro
Chips, Tuners & Programming
5
11-25-2015 10:08 AM
Simply67X
HVAC
14
08-21-2015 01:22 AM
karavansman
Wheels, Tires & Brakes
5
08-03-2015 06:19 PM
karavansman
07-20-2015 07:43 AM
Hawkz28
2
07-08-2015 09:08 PM
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
