Finally: Pics of my sub box and back bench
Well ive told people before in other threads that i was going to take pictures. And i slacked off and never got my A$$ out there to take pictures. I read in a magazine recently that if you plan to make a custom stereo box. So for now, the box is just cardboard. So forgive me on that. But the point of the pictures is showing the second 40% bench, and also the size and shape of the box im going to build eventually. I will keep ya'll posted once the box is made and upholsted.
Oh and i plan on stuffing two 12's in there with aproxemetly 1.5 cubic feet mounting space per sub.
Ill post the measurement here if anyone cares...
Lataz,
-Patrick
Lataz,
-Patrick
yea seats still fold down as were normally, unfortunatly i was unable to move the folding lever off of the drivers side seat to the outside. so its kinda a pain to fold it up and down, but it does look good. And as far as instalation, all of the holes lined up except one, which all i had to do was cut a small section of carpet out, and then drill and tap.
I took some more pictures today to show how i flipped the front support so it would be less drilling and things would line up better
And thanks, im trying to hold off on my two tires so i can spend my money on my system. And of course i will keep the pics coming.
-Patrick
-Patrick
Nice idea!! I went and bought an MTX enclosure that fits under the 60 bench and while it looks great and you'd never know it was there, you cant fold the seat down much past half, which kinda sucks. You might be onto something there with that idea of removing the 60 bench and swapping in a 40 with the sub box in the middle. What are you doing with the top of the box? It would make a nice place for some built-in cupholders and a maybe a small rectangular indent on to place stuff.
well right now the cardboard mock up makes a nice place to put all my stuff in the mean time. Hadnt really considered a rectagle indention like you suggested, i am kinda against putting cupholders which lead to spills over my electronic equipment. I wonder if i could take some random peice off of one of those new 04 flow thru consoles that would already be covered with the vinyl. hmm im gonna have to look into that.
Any suggestions on if it would be worth the effort to apolster it in vinyl instead of generic gray carpet?
And if someone can help clear things up, when they have a suggested mounting depth for a sub, is that the volume box it should be put into? or is it how much volume should be left over in the box after sub is installed?
Thanks for the comments and compliments so far they are appreciated.
-Patrick
-Patrick
whats the best way to seal the box? just use cualk? wood glue? anyone out there?
-Patrick
-Patrick
Ones that I have seen screwed the box together and then used caulk, btu I dont see why a liberal amount of wood glue wont work either. Then again, I'm not exactly an expert in the field of automotve acoustics either...
I have made a few systems for friends and my old Ranger, and I would really suggest Liquid Nail. Liguid Nail the edges of the boards where the screws go and then screw it down, then go on the inside and liquid nail all the imperfections in the box (small gaps or and bad spots in the wood) That has always been the way to go. I tried wood glue once and it wasnt that great (granted the wood glue i used was cheap).
Recessing a flat spot in there to place stuff is a great idea. I wouldnt do the cup holders either because you have 2 already in the center console for the back seat and its too close to the electronics. Keep it up man. One of a kind!
Brian
Brian
Patman, that is a really good idea for the box build.
What have you decided to make the box out of? MDF or fiberglass? Use LIQUID NAILS. Works great and provides a good seal after the box is built.
I built a small box for one 12" Pioneer under the bench and it worked out pretty well. Getting the individual seats and building the box in between is a great idea. Where did you get the seats from? I might have to rethink my set up.
Keep us updated...
Keep us updated...
I bought one of the 40% seats from a totaled screw owner. The other one is Stock/OEM.
Im going with MDF for my building materials. I still havent been able to build it or by my subs yet, ran into a need for brake work all the sudden so its holding things up.
Well i can put up more pics when ive got them.
-Patrick
-Patrick
