Who Has The Highest Mileage Supercrew?
#62
#63
#64
#65
#72
#73
I got a 2003 almost 98000 took it to the track the first time to see what i would run i ran a 16.92 at 79 mph i was impressed the only drivetrain i replaced is the rear diff, so i put locker and 4:10. the driverside where shaft gear sat inside the housing of the open diff it had like a 1/4 inch play. made some clunking noise after tearing it apart 2 times replacing bearing i found the problem oh and i changed all my coil packs at 70000 with the ones off ebay the ones that are like 8 for 90 bucks never had a prob since
#74
I have a 2004 Supercrew FX4, 5.4L with 106,500 miles. The oil changed consistently at 3k to 4k intervals along with tires rotated and balanced at the same times. I have replaced brakes, tires, alternator, front wheel bearing and unfortunately got a flat spot on one of the needle bearings and had to have the torque converter replaced - upside was I thought tranny was going. This things runs awesome, although I have a slight shock issue at the moment. I have K&N system along with Magnaflow exhaust and use Lucas Oil products, oil and fuel treatments. This thing is great in snow, mud and whatever else I can get into and still pulls the boat and a trailer full of quads great and yet still is very comfortable for long rides.
