03-30-2002, 10:38 PM
5.4 Supercharger addition??
I was wondering if anyone can drop me some info. about installing a supercharger on my '00 F-150 w/ a 5.4. I'm wondering how many internal engine mods I will have to make( heavier bearings, crank, etc.) to be able to handle the added power?
Any hints, tips, suggestions, would be greatly suggested. Thank you in advance....
03-30-2002, 11:06 PM
No internal mods needed. Just purchase a kit and bolt'er on up. What kind of power you lookin for?
03-31-2002, 01:56 PM
 I too am interested in supercharger info. I have seen post mentioning ATI and I have never before heard of thius brand. Is it a positive displacement type?
I have a 99 Expedition XLT w/ 5.4L, 2WD, 3.73 Limited Slip, 285/70-16's (factory size 255/70-16), Tow Package, Super engine cooling (larger rad & oil cooler)
My goals are, like most, to have more overall torque & hp avail from just off idle. I was considering Magnacharger & Kenne Bell (heard some unpleasant things on KB though)
Am I wrong in dismissing the ATI, Paxton, Vortex types? I hear that in the lower rev range that I spend most of my driving in they don't offer much boost (1500-3000). BUT am I missing something. Could it be that they offer less engine drag and have other benifits that would let my motor apper to run more or less stock untill I really want to smoke it?
What are the pros and cons of each setup?
Petrol
03-31-2002, 07:14 PM
 Just Looking for "a little extra "
04-01-2002, 11:52 AM
Sponsor & Technical Article Contributor
2000 Ford Expedition My Garage
Vehicle: 2000 Ford Expedition
Guys, definitely do not discount the ATI Procharger.
If a SCREW can run 14.3s in the 1/4 mile, it's hard to say they don't make any bottom-end power.
Of course, if the goal is off-idle power, go with the Magnacharger. If you spend time on the highway and make some dragstrip blasts, the ATI may better suit you.
Pics of Procharger and Magnacharger installations can be found in my Photo Album. Updated pics will be uploaded soon.
04-01-2002, 01:21 PM
Garage is empty, add now
Vehicle: 2001 Ford F150 KR
Have any comparisons on the Magna in a screw? I saw the numbers from the ATI, but the Magna appeals to me more. Just waiting for some concrete data before I spring for it, unless of course you can give me a discount if I provide a buttload of feedback data on it. Also, does the Magna use the stock air intake?
04-01-2002, 05:18 PM
Place a call out to NoDrive55. He's got a Screw (5.4L) with a Magna in it and I've seen him run 14.9's at the local track.
04-02-2002, 05:18 PM
CRASH!,
A couple of comments/questions on the pictures in your album:
Is/was the ATI installed on a 4.6 or 5.4?
In the pictures, the throttle body faces straight forward, on my 250 SD/5.4, the throttle body is angled towards the front left (drivers) corner of the engine - assuming the SC mounts in a similar position as shown in the picture, how would you expect the intercooler plumbing to be routed??
Again, the air intake plumbing was routed between the radiator and fan - I assume the fan shroud was removed/left off... was there a loss of cooling?? What about engine torquing/movement?
I've been leaning towards the ATI lately, due to ease of installation and inherent good low-end performace of the 5.4 making up for any possible lag from the ATI.
Keep up the good work.
Thanks,
Dan
2000 F 250 4x4 Lariat Crew
5.4L
Automatic
K&N FIPK, Magnaflow CAT back, Superchips - FlipChip
Transgo! Shift Kit, Sonnax mod valve
Roll-N-Lock bed cover
WAAG push bar, Power Stop slotted brake rotors
Cooper Discoverer A/T 285/75/16
http://www.f150online.com/galleries/...y.cfm?gnum=334
04-02-2002, 06:07 PM
Anyone hear about those new Holley superchargers? I was told they produce good results. Anyone have one installed? I would like to compare it to few others...
I'm looking for some good overall power gain. I just don't know where to go from here...
04-02-2002, 07:06 PM
Vehicle: 1999 Ford Expedition
Hi SVT - welcome to the board!
There was a guy about a year ago who put a Holley on his SD. He had some fit problems but worked through them and was happy with the end result. If you read the Holley webpage, it is pretty clear that they expect you to make things work for yourself (comments like "you will have to find a lightning alternator").
If the search feature was working, I would suggest a search of the Other Aftermarket forum for "Holley Supercharger".
Ian
99 Expedition EB
5.4l, 4x4, 4.10 LS, 285/70-17 BFG AT-KO's, Factory Tow with Extra 24k Trans Cooler
Magnacharger with Lightning I/C Pump Mod, WMS Tube, JBA Titanium Shorty Headers, Bassani/Gibson Cat Back Exhaust, Superchip Flipchip, PIAA Superwhites, Autometer Sport Comp Boost/Vac, Trans Temp, Fuel Press in 3 gauge pillar pod, Hellwig Rear Sway Bar, Motorcraft AGSF12FM1F4 plugs.
Current Project - BQuiet Extreme Throughout Truck - going very slow
Coming Soon - Remote Mount Oil Filter and Extra Engine Oil Cooler, Speaker Upgrades.
04-02-2002, 09:51 PM
Thanks Ian, I'll check that out....I heard about that Lightning Alt. too....no big deal!
04-02-2002, 10:29 PM
It's also interesting that the Holley kit costs $2500 more than equivalent running s/c's. That's the main thing that turned me away from them. Why pay that much more when you can get one that will do the same thing for $2500 less?
04-03-2002, 08:55 AM
The install pics you saw were of an ATI installed on a 4.6 L. On both engines, the fan shroud is cut to accept the intercooler tubes and there is no loss of cooling.
Please send pics of your application so we can take a look. We do believe we can install a standard 5.4 throttle body adapter and throttle cable brackets. We want to see if anything else will need to change.
In our experience, we have seen NO lag.
04-06-2002, 11:57 AM
Crash!
I've added photos of my F250 SD engine compartment to my photo gallery - I hope they show enough detail.... Let me know if you need any other shots.
Thanks,
Dan
5.4L
Automatic
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
