CAI issue, after replacing the Roush airbox?
Old 08-03-2014, 12:26 PM
widj's Avatar
Unhappy CAI issue, after replacing the Roush airbox?
Hi there,
the M112 came with a Roush airbox, I bought k&n 57-2556 ( http://www.knfilters.com/search/prod...x?prod=57-2556 ) and the engine will idle rough and dies, ideas?
First it doesn't fit right, but I was thinking of testing it first before getting a garage to find proper fittings for it.
The issue that I have is no matter how I install the k&n CAI the engine won't turn properly, like revving very low, seems like it is out of breath and dies after a few seconds.
I moved the MAF sensor to the k&n, it is plugged and also what I believe is a vacuum line, however from what I see, the Roush vacuum metal line sensor goes deeper in the tube of the CAI than the one from the k&n, might explain why or I am not sure.
Does the tune has to be updated if I am to use a k&n CAI?
k&n CAI, rough engine idling and die
stock CAI, takes time to get used to it for the first few seconds then all good
Old 08-03-2014, 01:28 PM
JEEZ.....the k+n vid clip sounds like yer killing it
first.....there's an arrow on the maf....make sure its pointed the right direction when the k+n is installed....
second....it looks as if the tube sizes are different where the maf is installed....that's a good indication that the tune needs to be rewritten
third....why switch???.... there's nothing really wrong with a roush air box....plus with the k+n with no box yer sucking in a lot of extra heat
Old 08-03-2014, 01:48 PM
widj's Avatar
first. yes it was pointed in the right direction, and there is no way to put it to the other direction, I checked
second. yes the maf isn't located at the same location, and tubing size is different, the roush tube seems to be larger
third. I want a loud whine, and I believe only a CAI can accomplish that..
Old 08-03-2014, 05:35 PM
different tube size requires tune changes = fact
current issue = operator error
resolution = put it back the way it was until you have a tune ready for the desired change
Old 08-04-2014, 11:31 AM
widj's Avatar
For those with a Roush blower on the 2004-2008 F150, if you have a CAI please pm me, as I'm desperately trying to adapt one for it.
JDM told me that the k&n air intake has a smaller MAF housing than the Roush inlet tube therefore making it more restrictive, I'll be returning the k&n kit.
I'm thinking of cutting the Roush tube just after the MAF and somehow make my own tubing with a cone filter, I'm expecting to hear the whine after that, thoughts?
I'm scare to cut it as if I do and it doesn't work then
Old 08-05-2014, 11:53 AM
Rambo274's Avatar
My thoughts exactly, you have done a number of mods to make power. I have been quietly reading, because, It might give me Ideas, for my roush sc.Then put on a cai that makes less power.... I'm confused on what you are trying to accomplish
Old 08-05-2014, 01:02 PM
I'm scare to cut it as if I do and it doesn't work then I'm
you want MORE WHINE????
uffda.....
get the blower ported plus pully it....larger lower with smaller upper
a Cai ain't going to change any sound except sucking air and you've already found that out....
Old 08-05-2014, 10:12 PM
widj's Avatar
blower is ported, silencer holes are filled, I can't put more boost than I have now (12PSI)
a CAI will make the whine louder, I don't understand why the 03-04 cobra are loud and the F150 verison of that M112 isn't, so lame
I'm thinking of cutting the Roush tube after the MAF and put a cone, but it looks tricky and JDM doesn't want to help me on that
Old 08-28-2014, 10:27 PM
rojomas's Avatar
Is this what you are looking for?
If you're lucky you might be able to find a Roush non-intercooled CAI somewhere.
I made it using two kits. First you need to find the CAI tube for a non-intercooled Roush f150 supercharger. You can find these sold separately.
Secondly, You need to find a Roush CAI for a normally aspirated 5.4 DO NOT buy one for a 4.6, they're not the same.
After that it's just mixing the two systems together.
BTW, mine works fine, No issues.
The reason I did it was because I didn't like the paper filter and because it's an odd size, only Roush makes replacements at $60. a pop.
Old 08-29-2014, 12:02 AM
widj's Avatar
that's exactly what I need lol!
but I can't find any part anywhere, can you show me a few sites with this please?
Old 08-29-2014, 12:15 AM
link>>> http://www.roushperformance.com/part...2004-2008.html
if I remember right airaid makes the roush kit....airaid part #401-140-2... http://www.summitracing.com/parts/aid-401-140-2
might still have issues with the maf in a different tube size...
Old 08-29-2014, 08:33 AM
That will defeat the MAF and cause all kinds of fuel/air ratio problems. Really a dumb idea.
Old 08-29-2014, 03:55 PM
widj's Avatar
it not the right one, this intake is for the non supercharged one, tubing is smaller than the one for the supercharger, also if you look at the entrance of the tube it is vertical, my supercharger is horizontal, will not work
ya I won't go for this kit, I might go with a custom made CAI, the tubing has to be larger and I will re tune it, I find it dumb to have a supercharger and not being able to hear the whine
Old 08-29-2014, 04:07 PM
contact roush....see if they have any for the non intercooled supercharger...imo
Old 08-29-2014, 05:35 PM
widj's Avatar
already did, those Roush CAI were discontinued a long time ago
Quick Reply: CAI issue, after replacing the Roush airbox?
