roushcharger with stage 3 cams
After thinking about this for a while I've decided to go with a non intercooled roushcharger, obx long tube headers, high flow cats, roush catbacks, e fans, and a saleen radiator. I just need to decide on the cams. Stage 1, 2, or 3 blower comp cams? I want the cam sound and good performance, but a little concerned about how mpg will be affected? And what power will this set up make? Thanks in advance for replies.
Obviously!! So why are you commenting???
Wrong!!!!
To the OP. you will be money ahead to use the intercooled kit. They are marked down to around $3500 right now and they are showing up in the classifieds both here and f150forum. Using the non intercooled kit and adding cams might get you close to the power you would have with the intercooled kit. And you will always be limited by not having the intercooler. Also adding a meth water injection kit and tuning for it will cost the same as just getting the intercooled kit.
So get the Roush intercooled kit, some longtube headers (dynotechs are the best)true 2.5" dual exhaust and you will have something. The Saleen rad isn't going to do anything for you. The stock rad performs just fine. And as mentioned above a Troyer tune.
If the OP'er is buying new then a secondhand IC version or even a whipple should work out cheaper. ($1200 whipple in Craig's list)
Even with the IC version IDE stay away from cams. There's plenty of other upgrades before hand. Better HE, maybe a KC. Comp cost $700 upwards. That money could get a real good Port & Polished head unit.
Unless you at least fit springs, the cam will only yield small gains and probably close to red line.
Twinskrewd, how long can you expect a stock motor with a cam and a blower on it to last? You obviously know more than I do about this, but I've seen JUST a cam trash motors within 50k miles when put on at brand new. His truck is 7 years old already. I'm thinking long term, no motor that's messed with like that is gonna last a very long time
The OP is worried about freaking gas mileage, which tells me that he'd probably be worried if his motor went. The truck is old enough to have 100k + miles on it, and I don't see a motor handling all of that with that kind of mileage on it (if it's that high), it stresses the motor. *And "lasting very long" is relative, so you can correct me all you want and tell me that that's wrong. But, "long" to me is 150k + miles. Not running a setup for a few years and rebuilding the motor. If you're gonna build a really strong motor that'll take the stress with no sweat, it's a lot more money that the OP is likely looking to spend. You're assuming that he's looking to blow a ton of cash on this. I'm looking at it from his viewpoint, he wants bang for the buck and decent gas mileage, and likely with it, motor longevity. He suggested using cheaper-end supercharger and headers to save cash. You're suggesting that he spend another $2k+ than he was intending to spend. Yes, that is definitely the better option for him, but it's likely a good deal of money for him spend. But we'll see when the OP posts again.
And btw, I said "I'm not experienced with this" out of respect for the guys like you that run all of this and know all the ins and outs and all the little details. I never told him exactly what to do or went into specifics; I used relative terms that are up to interpretation.
The OP never stated mileage on vehicle. And frankly it doesn't matter. If he's taken care of it and stayed on top of the oil changes he will be fine.
The OP mentioned a Roushcharger non ic, cams, OBX headers, highflow cats, catback system, Saleen rad, and of course he will need a custom tune . Thats $5500. He never said anything about it being cheap. It appears he wants boost, good power, good sound, and that cam'd idle every gear head loves. All good products but not the best bang for the buck, not the best combination, and power output would be severly limited. So I made the suggestions I did which can total $4800 to just over $5000 depending on the headers and exhaust he chooses. So how is it I assumed he is looking to blow a ton of cash?? And how did I suggest he spend so much more then originally planned? Damn you sound like a nagging wife about the money. I'll await your response
Now you mentioned engine longevity and building a motor to handle all this power blah blah blah. There is no reason whatsoever that the OP can't run 100k,200k, or even 300,000 miles with a supercharged 5.4 making
400+rwhp. Hell Mike Troyer has a customer in Alaska with the Roush kit on his and he recently turned 300,000. It's all about the tune and how you care for the truck. This engine has the same rods and crank the Lightning did. The only difference is the Lightning had cheap forged pistons and we have Hyperutectic. They pistons will handle the same power. The exhaust valves will melt at the same 1515F. You mentioin building a motor that can handle
stress. Well the 5.4 3V is perfectly capable of handling the stress of 8-10psi or 400+rwhp and living a normal operating life span. Hell I push 475rwhp daily with 86lb wheel/tire and I push over 500rwhp at the strip and mines doing just fine. Been this way for 50,000 miles. Oil anaylsis show she is wearing better then the stock 5.4 under normal use. And to top it off I drive the hell out of it. But I take top notch care of it. And yes my engine is bone stock. Never cracked a seal. Plenty of others here and on other forums with SC'd trucks and no issues. Thousands of Lightning, Harleys, Roush Stage 3, Nightmares, and Saleens doing it to. And these are all manufactured this way. Not some grease monkey like me adding a blower.
