Go Back   F150online Forums > Powertrain & Mechanical > Superchargers & Turbochargers
Sign in using an external account
Register Forgot Password?
Register Photos Vin Decoder FAQ Members Search Today's Posts Mark Forums Read VendorsGarage
Thread Tools Search this Thread Display Modes
Old 03-15-2012, 11:30 AM
2005 Ford F-150
My Garage
Vehicle: 2004 Ford F150
Send a message via Yahoo to Huitt24
Stiegemeier Venum cooler
Well I had to do my timing chains on my truck so I decided to send my blower of to stiegemeier's to be rebuilt since they already ported it I decided to get my upper plenum ported and the new venom snout cooler installed while it was there. I also did some powder coating on the trucks valve covers timing cover and water crossover while I was waiting. here are some pics.
Venom cooler
Click the image to open in full size.
upper plenum before
upper plenum after
Old 03-15-2012, 11:32 AM
2005 Ford F-150
My Garage
here is the powder coating
Old 03-15-2012, 11:34 AM
2005 Ford F-150
My Garage
Venom cooler installed
the venom cooler has shown a 100* drop in blower temp on the front half of the blower to even it out with the rear temp. On the Roush with the longer snout they have seen up to 125* cooler. So hopefully this will help with the heat soak in the summer
2005 XLT Scab 5.4L, Roush Stage 1
Drilled/Slotted Rotors
Pace Setter long tubes, magnaflow 2.5" x-pipe and dual in/dual out Magnaflow Muffler,
Ground Force 2/5 drop with Belltech 1" drop shocks, Hellwig rear sway bar.
Old 03-15-2012, 12:48 PM
Garage is empty, add now
Vehicle: 2007 Ford F-150
Nice work. Got to see the Venom cooler with a Snake Bite when I was at Troyers. Have you thought about adding a heat exchanger, switching to a larger one, or a double pass?
12.7@106.62MPH 60' 1.73
475RWHP 532RWTQ WHIPPLE CHARGED Troyer Tuned Built By Me
Dyno Sheet & Video
Click here>>> http://www.f150online.com/forums/sup...p-532rwtq.html
Old 03-15-2012, 02:05 PM
BOOBIESFORME IR0NS1N
Send a message via AIM to IR0NS1N Send a message via MSN to IR0NS1N
That's ufcking sexy right there
Old 03-15-2012, 04:01 PM
2005 Ford F-150
My Garage
Quote:
I had two heat exchangers but ended up burning up my intercooler pump. I have since mounted the roush heat exchanger out front above the trans cooler. I am thinking about adding a larger tank that I can add ice when I am at the track
Old 03-15-2012, 05:12 PM
Vehicle: 1997 Ford F150
Send a message via AIM to Faster150
damn i didnt even know IAT's got above 100F!! then again i have a procharger...
Old 03-15-2012, 08:36 PM
Quote:
Has nothing to do with IAT's. Though I think you mean ACT's. This is a way to cool the snout to prevent premature seal failure. The snout on the Eatons get insanely hot while racing or just during some spirited driving.
Dyno Sheet & Video
Old 03-15-2012, 11:56 PM
1998 Ford F-150
Vehicle: 1998 FORD F 150
It's OK, I still call em' iat's too.....tomato / toamatto
Old 03-16-2012, 06:37 AM
FATHERFORD FATHERFORD
Send a message via AIM to FATHERFORD
You live in texas where over 100 degrees is common.... how could you not know that?
The Saleen JDM'd 5.4 3v
Winner of F-150Online's Best Sounding Exhaust 2010.
Old 03-16-2012, 06:39 AM
BTW aweomse jack!
Everyone is working on their trucks but me..
I keep fighting withmyself on what to do. I want to build the engine in my truck, but then I also want a procharger for the viper, then I also want to finish my 92 coupe and have a 9 second car finally.
Old 03-16-2012, 08:54 AM
Quote:
Seriously!?! The temp of the air pre-blower verses the temp going into the cylinder post blower is like tomato vs toamato. Wow Prochargers really are amazing. They have completely rewritten the laws of physics
Old 03-16-2012, 08:56 AM
Quote:
Originally Posted by FATHERFORD View Post
BTW aweomse jack!
Well if it makes you feel any better I'm not doing anything new. Shopping for tires. Starting to think I should start running drag radials full time. On another note spring has sprung here in the Carolinas and its time to go racing.
Dyno Sheet & Video
Old 03-16-2012, 12:42 PM
Sponsor & Technical Article Contributor
2000 Ford Expedition
My Garage
Vehicle: 2000 Ford Expedition
Send a message via AIM to Crash! Send a message via Yahoo to Crash!
Mark and I have tested the ProCharger and a T-67 turbocharger on the same truck, with a Dakota Digital ACT guage. Both systems used air-to-air intercoolers. The 3-core is very efficient and brings charge temp down to ambient (Outside temperature). While driving, under hood temperatures never fell below 110-120 degrees. This was in Houston in the middle of the Summer.
Under full boost, the P1-SC ProCharger discharge temp was 180 degrees and at the throttle body charge temp was 100 degrees on the trip home from the dyno.
I firmly believe in keeping the compressor cool. I am interested in seeing the end result charge temps after installing the Venom system!
Nice work Huitt!
View ProCharger animation here...
Derek (AKA Crash!)
Trixters Racing LLC
Mild to EXTREME! Blown sleepers a specialty!
Paxton, Vortech, ProCharger, Whipple, STS, Magnacharger, and Explorer Express.
Please PM or call 918-899-7242.
Trixters Racing online photo album...
TrixtersSpeed Youtube channel...
Old 03-16-2012, 06:10 PM
on the highway i never saw IAT(charge air temps) above 100F unless i was stopped in traffic with heat soak the hottest it got was 146F. but i never race if my IAT's are above 100F
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company
Emails & Contact Details
Search Engine Friendly URLs by vBSEO 3.5.2
