Home Discussion Forums Photo Gallery Vendor Directory Technical Articles Recalls & TSB's Product Reviews Classifieds Ford & Industry News Vin Decoder Advertise with us
Go Back   F150online Forums > Powertrain & Mechanical > Superchargers & Turbochargers
Sign in using an external account
Register Forgot Password?
Look for a USED Ford F150
Carsdirect.com
Thread Tools Search this Thread Display Modes
Old 01-21-2012, 01:29 PM
1997 Ford F-150
Vehicle: 1997 Ford F150
procharger belt slip
Just got truck back from Troyer Performance, and belt slip was once again the major issue. It pulls great to about 5200 rpms then the belt starts to slip so boost won't keep rising at that point. Truck is a 97 4x4 4.6l 5 speed with a D1sc 6 rib pulley setup. Does anyone know of a company who sells pulleys that grip better? It's annoying as Hell knowing that if not for belt slip, the final dyno numbers would be much better. Any help will be appreciated. THANKS!!!
Old 01-21-2012, 03:39 PM
Garage is empty, add now
Vehicle: 2002 FX4 Screw
Maybe you could find a cog belt setup???
Current ride...
2002 FX4 Screw with a flex a lite Efan installed
L swap supercharger work in progress...
Still gathering all the parts I need for the swap
Old 01-21-2012, 04:23 PM
Ac delco. Back when my Stang had a vortech that was the only belt I would run
Old 01-21-2012, 05:57 PM
1997 Ford F-150
Tried different belts but none helped. I don't think they make 8 rib setup for my truck also. Wasn't there a company that used to coat the ribs with something to help with grip? Cog setup would probably cost a fortune if it would even work.
Old 01-21-2012, 07:39 PM
1997 Ford F-150
Just found the Riechard Racing ultra grip pulleys are available for the procharger. Anyone know anything about them, or using them?
Old 01-21-2012, 10:23 PM
Send a message via AIM to Faster150
Quote:
idler pulley is 32 bucks from autozone, its off of a focus. then just get some fender washers and a nut and bolt. drill mount use the washers for shims to shim the pulley out then just get a longer belt. i was able to get 10psi out of stock pulley and no more belt slip!
Old 01-23-2012, 06:44 PM
Vehicle: 2007 Ford F-150
What were your final numbers? Is your truck black? I saw a late 90's truck with a Procharger on it when I was up there. If it was yours thats a nice looking rig
475RWHP 532RWTQ WHIPPLE CHARGED Troyer Tuned Built By Me
Dyno Sheet & Video
Click here>>> http://www.f150online.com/forums/sup...p-532rwtq.html
Old 01-23-2012, 08:15 PM
1997 Ford F-150
Yep that was mine. It's a 97. Mike had it to 440 before the belt started slipping.
Old 01-24-2012, 10:57 PM
damn 440hp how much boost are you pushing??
10-12?
Old 01-24-2012, 11:06 PM
1998 Ford F-150
Vehicle: 1998 FORD F 150
440 is impressive. I wonder how much hp is saved going through a manual trans?
More pics/nice job here: belt slip fix
Old 01-24-2012, 11:10 PM
hey theres my old thread lol
Old 01-25-2012, 02:48 AM
1997 Ford F-150
Quote:
10-12?
I think it hit 13 lbs once.
Old 01-25-2012, 02:56 AM
1997 Ford F-150
440 was ok I guess, but I was really hoping to see 500, and it looked like we were going to get there before the belt started slipping.
Old 01-26-2012, 10:24 AM
Sponsor
1999 Ford Expedition
My Garage
Vehicle: 2002 Ford F-150
Send a message via AIM to Crash! Send a message via Yahoo to Crash!
Great numbers. Nearly 100 HP over the P1 as we have seen before.
Like I said on another thread, the D1 is much more powerful. Once you resolve the belt slip, you should see a 1-3 PSI increase. There is no cog setup for our trucks and it gets expensive to upgrade the drive system. Cogs are difficult and hard to set up because they do not use spring loaded tensioners. They have to be setup perfectly and are generally NOT for street use. Now ATI is mounting the F series blowers up front and run direct drive and NO belt or gear drive.
No 10 rib pulleys are available from Procharger and I have them searching for an 8 rib setup because I was told there is a pulley out there we can swap and do an 8 rib. Keep in touch, because they will call me with options. As I remember, it was an aftermarket Mustang GT balancer and a pretty expensive billet crank pulley. Based on the conversation, the crank pulley is what will hold us back. I intend to run an F 1A and will need to contact MadEnterprise for a custom pulley based on how things look now.
Faster F150 has the best solution I have seen for the 6 rib.
Until then, check tightness. A good rule of thumb is to twist the belt on its axis and you should only be able to twist it 90 degrees. I was at the dragstrip one time and my belt was too tight and squealed like a pig so ensure it is not too tight because it will glaze the belt and then it will slip.
Derek (AKA Crash!)
http://www.trixters-racing.com
Mild to EXTREME! Blown sleepers a specialty!
I will be out of the office for a couple of weeks for medical attention.
Please contact Bill at 918-605-5885 and I will get your messages.
Not in a hurry? Please PM or call 918-899-7242.
Our online photo album...
TrixtersSpeed Youtube channel...
Old 01-30-2012, 09:27 PM
1997 Ford F-150
Crash. Let me know if you find a solution to the belt slip. What about the Riechard Ultra Grip Pulley? It sure looks like it would help.
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
F150online - Archive - Top
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.2
Emails & Contact Details
