Go Back   F150online Forums > Powertrain & Mechanical > Superchargers & Turbochargers
Sign in using an external account
Register Forgot Password?
Register Photos Vin Decoder FAQ Members Search Today's Posts Mark Forums Read VendorsGarage
Thread Tools Search this Thread Display Modes
Old 12-03-2011, 12:01 PM
2000 Ford F-150
Procharger Set Up
Alright everybody, I'm new to all this supercharger set up stuff. I have a 2000 F150 LA West Edition with a 5.4. Since I have had it has blown a spark plug out of the passenger side #4. When it did a piece of the plug went down itside of the cylinder wall and bruised the wall, So I pulled it and took it to get redone. During the process I decided to go ahead and put some money into it and had it honed out and then built up. We kept the standard bore but upgraded it with a better forged bottom end. I had the heads ported and polished and had a 4 angle valve job done. I called Comp Cams and told them what I wanted to get out of the truck and they set me up with a set of cams that make the truck sound very nasty. I put shorty headers with a true dual exhaust with 2 Magnaflow Cats, with a X pipe and Aero Turbine mufflers. I still have the 19lb injectors and it gets plenty of fuel. Also custom tuned by Troyer. The truck runs very good and I am pleased with it but I want more. It will run high 14's with no problem. I still have the stock transmission but I plan on putting a Factory Tech Valve Body in very soon.
Now on to the Procharger. I Can't decide if I should go with the P-1SC 2 core, or the D-1SC 3 core. My thing is I want boost to be there when I punch it. But I also don't want to get the P-1SC and it not be enough power. How much boost do you think I can run safely? How much boost can I get out of the P-1SC compared to the D-1SC. What can I do to get instant boost out of it? Should I get injectors and a mass air or is the fuel pump they supply going to be enough? I need all the info I can get before I do this so I can do it right the first time and not have to do double the work.
Thanks.
Old 12-03-2011, 09:03 PM
1998 Ford F-150
Vehicle: 1998 FORD F 150
D-1SC three core, better too large than too small.
Read here:http://www.musclemustangfastfords.co...l/viewall.html
Old 12-03-2011, 11:10 PM
Garage is empty, add now
Vehicle: 2001 Ford F150
Contact Crash on the forum. I called him about getting set up with a procharger and he is knows his stuff. He can tell you everything you need.
2002 4x4 XLT ford f150 CNG
Old 12-03-2011, 11:46 PM
2001 Ford F-150
My Garage
Vehicle: 200? FORD
Send a message via Yahoo to tarajerame
D1SC with the 3 core for sure, 39# terminator cobra injectors, 12# of boost, A SCT BA2400 MAf, a solid tune, a better bypass valve and enjoy it...
Old 12-05-2011, 11:14 AM
Quote:
then you don't want a centrifugal blower like the P1/D1. You want a roots or twin screw blower. The centrifugal will gradually build boost in the upper rpm, while the roots/twin screw boost will be more instantaneous.
Old 12-05-2011, 03:57 PM
2000 Ford F-150
So it won't hurt anything if I go bigger? It won't make to much boost right out of the box? Slothman86, Wouldn't I have to change to much to go with the roots setup? Isn't that the same as the lighning setup? Tarajerame, Didn't you have the same setup on your truck?
Old 12-05-2011, 06:21 PM
Vehicle: 2003 Fast Screw
Quote:
X2
594/620 Without the nitrous!
Built Lightning block.
Stage 3 Ported heads. high performance Cams
2.3 Kenne Bell L upgrade blower 16 PSI
Kooks long tube headers
BTS race built 4R100 tranny
100 shot of nitrous
best 1/4 to date.
60' 1.68
11.76 @ 116.17
Old 12-05-2011, 11:01 PM
2001 Ford F-150
My Garage
Vehicle: 200? FORD
my green truck made max torque at 2400rpms when it was centrufigal equipped, it made max boost at 5400rpms as that's where my rev limiter was set at
yes I am switching to a different setup, but I enjoyed my procharger and I miss it
-LOTS OF PARTS FOR SALE http://www.f150online.com/forums/par...-new-post.html
Old 12-06-2011, 06:05 PM
Sponsor & Technical Article Contributor
2000 Ford Expedition
My Garage
Vehicle: 2000 Ford Expedition
Send a message via AIM to Crash! Send a message via Yahoo to Crash!
Since I am hearing "instantaneous boost" and Roots type in the same sentence, I will throw this out there.
We can upgrade from the P-1SC up to an F-1A that will even the score and it will be a comparable price. With a 5:1 step up ratio, it will be a killer off the line. In fact, my Expedition will get one. Don't forget to look at the F- Series IF you want to compare the 2.3 to a comparable centrifugal. My money goes on the Procharger if both units are tuned correctly and both spraying a 100 shot...
We also suggest the D-1SC before the P-1 these days because I have seen magazine results the swap from P-1 to a D-1SC and a 5.0 gained quite a bit more power than the D-1SC (100 HP). In fact, we have sold very FEW P-1SCs once we installed a D-1SC. Plus the 3 core intercooler as well. Below you will see the largest ProCharger we can bolt on these Triton engines. So you can imagine what the race blowers will do in comparision to the 2.3.
http://www.procharger.com/tech.shtml
http://procharger.com/fseriessuperchargers.shtml
View ProCharger animation here...
Derek (AKA Crash!)
Trixters Racing LLC
Mild to EXTREME! Blown sleepers a specialty!
Paxton, Vortech, ProCharger, Whipple, STS, Magnacharger, and Explorer Express.
Please PM or call 918-899-7242.
Trixters Racing online photo album...
TrixtersSpeed Youtube channel...
Old 12-06-2011, 06:21 PM
My Garage
In other words, compare apples to apples.
http://procharger.com/models.shtml
Derek (AKA Crash!)
Trixters Racing LLC
Old 12-06-2011, 06:36 PM
What numbers are u expecting from ur expedition crash ?
Old 12-06-2011, 07:18 PM
My Garage
I think I would be happy to have 600+ RWHP on tap, but it takes time and FUNding. And a big blower.
Derek (AKA Crash!)
Trixters Racing LLC
Old 12-06-2011, 07:37 PM
That's great will u keep ur stock intake manifold
Old 12-07-2011, 03:47 PM
2000 Ford F-150
Thanks Crash. I will have to compare and see how my money goes. I'm trying to have some money left over after all this set up but most likely won't. Tarajerame, Do you still have your Procharger set up? And where do you'll think is the cheapest place I can get it? Or maybe a good used setup?
Old 12-07-2011, 04:50 PM
2002 Ford HD #04417
My Garage
Vehicle: 2002 FORD/HD #04417
Keep you eyes in the classifieds .....one pops up every once in awhile...
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company
Emails & Contact Details
Search Engine Friendly URLs by vBSEO 3.5.2
