remote mount turbo?
You can try some browsing here, an open forum. Locate a Sniper forum and do some comparing.
http://www.modularfords.com/forums/f149/
EDIT: I should add that the datalogs using SCT's LiveLink software can be viewed using Excel or LL. LL is a free download from SCT.
Have you considered what you are going to do about that wastegate being set up for probably 20psi? Have a BOV open at all times?
If you are going to buy a cheap turbo at least get one that will be close to what you want, you would be better off with a cheap ebay turbo that is the correct size and externally wastegated
